Fleetguard Antifreeze question
   / Fleetguard Antifreeze question #1
LouHill
Cincinnati, Ohio
John Deere 770
I am using Fleetguard Antifreeze with additives that I purchased at my local TSC store. I'm using it in a John Deere 770 diesel tractor (24 Hp). Can anyone tell me how often I should change this antifreeze. I understand the additives go bad after a while. Can I get by with changing the antifreeze once every two years? Thanks for your views on this matter.
   / Fleetguard Antifreeze question #2
You can have the antifreeze tested or get test strips I believe. However in that application I don't think there is a problem if you change it every 2 years.
Ben
   / Fleetguard Antifreeze question #3
Two years is about right but be sure to use only distilled water as the solute.
   / Fleetguard Antifreeze question #4
I would just replace the coolant. The tests strips are like $2 each I think, while the coolant is like $7 per gallon...
When I had my powerstroke diesel I only used strips to tests the SCA level. The freeze point etc was the normal way.
Thanks for your replies! I feel better knowing two year antifreeze changes are appropriate.
NEW 24ft Feed Bunk Wagon (A55218)
NEW 24ft Feed Bunk...
JOHN DEERE/UNVERFERTH 1700/330 LOT NUMBER 13 (A53084)
JOHN...
EZ-GO MPT 1000 Electric Utility Cart (A51691)
EZ-GO MPT 1000...
Bush Hog 9670 8FT Pull Type No Till Grain Drill (A55218)
Bush Hog 9670 8FT...
2013 COACHMEN CATALINA TRAVEL TRAILER (A52472)
2013 COACHMEN...
