Fleetguard Antifreeze question
   / Fleetguard Antifreeze question #1
LouHill
Cincinnati, Ohio
John Deere 770
I am using Fleetguard Antifreeze with additives that I purchased at my local TSC store. I'm using it in a John Deere 770 diesel tractor (24 Hp). Can anyone tell me how often I should change this antifreeze. I understand the additives go bad after a while. Can I get by with changing the antifreeze once every two years? Thanks for your views on this matter.
   / Fleetguard Antifreeze question #2
You can have the antifreeze tested or get test strips I believe. However in that application I don't think there is a problem if you change it every 2 years.
Ben
   / Fleetguard Antifreeze question #3
Two years is about right but be sure to use only distilled water as the solute.
   / Fleetguard Antifreeze question #4
I would just replace the coolant. The tests strips are like $2 each I think, while the coolant is like $7 per gallon...
When I had my powerstroke diesel I only used strips to tests the SCA level. The freeze point etc was the normal way.
Thanks for your replies! I feel better knowing two year antifreeze changes are appropriate.
2000 POLARIS MAGNUM 325 ATV (A51406)
2000 POLARIS...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55301)
NEW HOLLAND 706 30...
2007 FORD F750 XL SUPER DUTY SERVICE TRUCK (A51406)
2007 FORD F750 XL...
2018 PINSA 130BBL VACUUM TRAILER (A53843)
2018 PINSA 130BBL...
2015 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A53422)
2015 Chevrolet...
2015 Ford Transit 150 Cargo Van (A53422)
2015 Ford Transit...
