Flatbed truck plans
/ Flatbed truck plans #1
RHughes
Autauga County, AL
New Holland TN65
This post is slightly off topic, but I thought the group would have some good input.
Friday I dinged the tailgate of my "good" truck one too many times /forums/images/graemlins/blush.gif and came to the conclusion that I need a second truck, a 1 ton dually, to pull trailers and use around the farm. I found a pretty good F350 diesel but it needs a bed.
Does anyone have, or know where I can find, some plans for a flatbed truck body? I'd like to get some idea of the difficulty and make a "buy or build" decision.
Thanks for the input!
/ Flatbed truck plans #2
I'd find a place that sells them, and check it out really closely. Seeing how it is built should give you an idea of how you would build one.
Then it's just a matter of estimating time and material, assuming you have the tools/skill level required.
Not a hard task, but would take some time.
Ron
/ Flatbed truck plans #3
Try Whitworth's in Deatsville. He had a decent selection and pretty good prices.
/ Flatbed truck plans #4
I have made them out of pressure treated lumber for years.4x4 and 2x6's and the have always outlasted the truck. About the only hard and fast rule is.....make sure it will clear the tires under load!!! /forums/images/graemlins/shocked.gif /forums/images/graemlins/laugh.gif
</font><font color="blue" class="small">( Try Whitworth's in Deatsville. He had a decent selection and pretty good prices. )</font>
Didn't think of that! I've bought several implements and various parts from him; always been pleased. I may head over there this weekend and see what he has on the lot.
/ Flatbed truck plans #6
Off the rack one size fits all nine foot flatbeds usually start around seven to eight hundred dollars carry out.
I prefer building my own. The biggest reason is the factory quickies layer build. There's two rails that fit on your truck rails. Then the cross pieces are welded on top of those.
So right off the top your bed starts off being eight inches higher than a factory pickup bed.
I've built quite a few beds and as far as I'm concerned it's the only way to go. Doing it yourself you can do the things they won't or can't because of the cost of labor.
On the west coast the bed makers used to use oak decking. I once bought a factory bed unassembled eight by twelve foot. I then welded it up but did all the little things that made it work so much better.
Here's some tricks.
Height. I measure the distance from the top of the differential to the bottom of the truck frame. Add one quarter inch unless you plan on big loads and bigger tires.
I've found rectangular tubing better for the running rails that sit upon the truck frame. That makes it easier to weld cross peices between them. This lowers the bed the distance of the width of the cross pieces. Always use U bolts and a hardwood spacer between the truck bed and the truck frame when you can.
Tail and marking lights are a snap if you use the pop in style. They don't break as easy if accidentally bumped.
If you want to use the oblong boat style sealed pop in the cut out is really simple. Two and a half inch holes with a four and a quarter inch centerline. I usually use a hole saw to make my marks outlining the two and half inch circles. I then scribe a straightline between the two holes. A second with the plasma and it's nothing but a thing. Perfect fit every time.
Without the plasma I'd drill the two holes and then saw cut the piece out between them. A little slower but still a perfect fit.
You can buy stake pockets at a trailer supply if you don't want to make your own and want removable side boards. While there you can find all kinds of tie down attachments. You can't have two many tie downs.
If you decide to use stake pockets with a rub rail be sure and leave more than an inch an a half spacing between the rub rail and the edge of the bed. Two and a half is best. Two inch is minimum.
Build it yourself. Don't let them have all the fun.
Thanks for the advice! I'm leaning toward the "home built" solution. I think I can build a bet with a better, custom fit that going with a factory built fit-all solution.
/ Flatbed truck plans #8
You might want to call some salvage yards and body companies around your area and see what used inventory they might have. If nothing else you could use one as a starting platform and customize it from there to fit your needs.
/ Flatbed truck plans #9
RHughes,
Is that scrap yard "Sables" still in business in Montgomery? They always had more great stuff than I could afford! Air Craft fittings, Industrial stuff and Steel ... you name it (and some I couldn't name) it was more than likely there!
Leo
Yes, Sabel Steel is still here. They have a cleanup service that probably draws in some really good "stuff".
There's another one too, MIMCO (Montgomery Iron and Metal). They have mountains of used stuff. I think they deal mostly with bulk scrap rather than trying to sort out salvageable material. A company I used to work for sold our scrap brass and copper to them.
/ Flatbed truck plans #11
If you're gonna build one,you might want to add this feature.I made the side rails for my dump trailer double as loading ramps for my tractors.The forward bulkhead is mounted rigidly and all four corners are "hinges" welded up out of angle and half inch pipe,pinned with half inch round rod.I made stake sockets out of pipe for side stability.Matching brackets are mounted to the rear for the rails.Pull the pins,move the rails to the rear and pop the pins back in!! I'm sure someone has done this,but I don't recall seeing it.It gets lots of attention at the shows...'bout as much as the ole boys stratching their heads over my rotary plow /forums/images/graemlins/laugh.gif
/ Flatbed truck plans #12
I guess that I will have to go by Sabel's the next time up that way. I don't know MIMCO nor where it is. But if they are bulk scrap they wouldn't like some one digging around the stacks.
Thanks,
Leo
/ Flatbed truck plans #13
Ask someone at the scrap yard if they sell or know who does,salvage steel.Turns out our local new steel supplier does exactly that! Anything in the yard for a quarter a pound.I picked up 48 feet of 2x4 11 guage tube for 65 bucks.Might not be a pretty...but I'm a Rustoleum slopper...
/ Flatbed truck plans #14
Howdy-
I've built a few truck flatbeds. Nothing fancy, but good, functional, "ag" type beds.
I documented the last one I built with pictures and wrote up an article and posted it here.
Possibly it will provide some help/ideas.
Best,
Mark
/ Flatbed truck plans #15
I can't picture it - but I like the idea. Pictures - Please!
EXCELLENT ARTICLE!!
I'm bookmarking that for future reference /forums/images/graemlins/grin.gif
Thanks!
/ Flatbed truck plans #17
Question?? What thickness steel do you recommend for the frame rails and cross supports? I won't be hauling real heavy stuff on it, but I don't want to build it too light or go too heavy either. I purchased an older F350 to pull the 14K trailer I just built and wanted to build a flatbed for it. Any suggestions?
/ Flatbed truck plans #18
F350 is comparable to a 5 ton sprinter in Europe: We used to make beds on those Sprinters with 60x40mm cold rolled C channel with 3mm wall thickness as crossties, a 100x40 or 50 side profile all around, and 120x60x4mm runners. The height of the runner is mostly chosen because of the height between the tires and the frame. Our custom built beds were popular at construction and scaffolding companies that had lots of seasonal workers, that therefor used equipment like they stole it. Factory made beds were all of 2mm pressed steel.
To determine how high you want your deck to be, measure the distance between the axle tube and the rubber bumpstop on the frame, then add an inch which the rubber will flex (judge that extra distance based on the shape of the rubber)
Best is to sketch it all out on a piece of paper to keep in mind where your measurements go, so you dont get confused.
/ Flatbed truck plans #19
Thanks. I have some 3"x2"x3\16" (.1875 wall thickness) rectangular box tubing for cross members and 4"x4"x1/4" (.250) angle to wrap the bed with. I may swap the angle out for some lighter weight c channel. So all I really will need to pick up is plate for the decking, channel or box for runners (once I determine the height I need), and steel for the bulkhead and hitch.
/ Flatbed truck plans #20
I often use "van trailer" cross members for my trailers. The "Fruehauf " ones are made from *
80,000psi steel..They are light and strong , easy to weld also..If you cut the cross members into the side rails it will keep the deck height lower..They are available in 4" and 3" heights..
NEW Wolverine 66" Skid Steer Bucket, 38" Depth (A62679)
NEW Wolverine 66"...
New/Unused Landhonor 8ft x 10ft Galvanized Apex Roof Metal Shed (A65583)
New/Unused...
Frontier QA Pallet Forks (A64126)
Frontier QA Pallet...
New 20'x20' All Steel Carport (A62679)
New 20'x20' All...
7' Pallet Fork Extensions  (A62679)
7' Pallet Fork...
2002 Massey Ferguson 1233 Tractor (A66285)
2002 Massey...
