Tires Flat Tire...Now what?
/ Flat Tire...Now what? #1
AlabamaFarmer
Minooka, Alabama
MF 1533 4WD
I've got a flat front tire on my 1533. /forums/images/graemlins/mad.gif I tried to air it up with my little compressor but the tire won't hold air. it's come off the rim. What size are the lugs? I guess I'll take it off and get it fixed.
/ Flat Tire...Now what? #2
Got a flat tire a couple weeks ago on my GC2300 (front right). Had my dealer fill both front tires with foam. It adds weight and there are no worries of flat tires again.
Cost ~$130 to do both tires. If I would have had all 4 done at the same time, the price per tire would have been less due to setup.
/ Flat Tire...Now what? #3
I have had my front tires foam fill for about one year now
and no more flats I like them
DougM
/ Flat Tire...Now what? #4
You will more than likely need to get it up off of the ground. If you have a loader it is easy, if not get a jack.
/ Flat Tire...Now what? #5
</font><font color="blue" class="small">( I've got a flat front tire on my 1533. /forums/images/graemlins/mad.gif I tried to air it up with my little compressor but the tire won't hold air. it's come off the rim. What size are the lugs? I guess I'll take it off and get it fixed. )</font>
Get the tire off the ground.
Wrap a tie down strap around it then shoot the air to it .
Beed should pop out to the rim and seal off.
/ Flat Tire...Now what? #6
The first thing to do is step
#1 jack it up so you can spin the tire freely then
#2 put some dish soap on the bead and rim lip
#3 Wrap a tie down strap around it and then
#4 shoot the air into it . like poster LBrown59 said after that it should be back on the rim .
PS the soap trick I learned from my dad who was a tire man and for best results you need a air compressor with tank not those little 12 volt air compressor . they might work but it will take a while with them along with cussing /forums/images/graemlins/grin.gif.
2003 Odyssey Lextra 2502 Pontoon w/ 2009 Bagg Boat Trailer (A62613)
2003 Odyssey...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
2005 C7500 20' Box Truck (A62613)
2005 C7500 20' Box...
6' Bush Hog (A62613)
New/Unused Wolverine 78in Quick Attach Smooth Bucket (A65583)
New/Unused...
2021 Takeuchi TL6R (A64126)
2021 Takeuchi TL6R...
