Flat face hydraulic connectors are better?
/ Flat face hydraulic connectors are better? #1
Nemmy
WA
Kubota L47 soon?
I’m figuring out some front end loader attachments and was told that using flat face hydraulic connectors is better for continuous flow applications. Is that true? I’m trying to figure out if I should change the connectors on the 3rd valve on the tractor or pushback and change the two attachments I’m looking at.
Right now the cost would be a push. Trying to make the right choice for the future.
Thanks.
/ Flat face hydraulic connectors are better? #2
I prefer them.
You will have posters say not to use them and others say only use them.
In general they cost more.
They leak/drip less on disconnect.
Much easier to keep clean and debris free.
Some say the FF lock up under pressure and can not be connected without "cracking" a fitting. Never seen that myself. I have seen that however with the ag connectors (ISO 5675 and ISO 7241-1 Series B connectors.)
The FF FIRG ISO 16028 connectors have been great.
The big boys (read big equipment) all use FF that says something to me.
/ Flat face hydraulic connectors are better? #3
I prefer them.
I have a third function for my 4n1 on my FEL. It uses the FF connectors. One side ALWAYS locks up when removing the 4n1 to put my forks on - or whatever it does it regardless of the fact that I always "stir" the hydraulics to relieve pressure (including operating the 3rd function and stirring) before I disconnect the bucket. I ALWAYS have to crack the fitting to relieve pressure. I don't know if this is a "function" of the FF or if it is something to do with the way the 3rd function was installed but it is a fact of life. I plan to install an inline valve so I can crack it open to relieve pressure when I go to reconnect.
Oh yes, the line I crack is on the 3rd function, not on the bucket.
/ Flat face hydraulic connectors are better? #4
I have dozens of the 3/8" (Tool Size) FF couplers in use. Just hate them!
Can't use them in the winter without a torch handy
Can't connect them with even the slightest pressure as with temp changes
The collar gets bent and ruined if they hit cement when falling on the ground
Various different manufacturers tend to leak when used together
Maybe it's just the 3/8 size, who knows?
/ Flat face hydraulic connectors are better? #5
Mine are 1/2" and this is the only one I have problems with, but it is also the only FF quick connects I have on the tractor, at least ones that I use regularly. My hoe connects with the old Series B ( I think) Parker and they work great, albeit with a touch of fluid leak when breaking he connection. I think I'm going to change them out for the old style since this bucket is on and off frequently.
/ Flat face hydraulic connectors are better? #6
As for flow, the flat faces are available that flow higher rates than ag style, but the 1/2” ag style will flow more than your tractors system does. As for which people have more issues with is a toss up, I’ve seen about as many posts about FF locking up as I have ag style. The FF do drip less then the ag style , so it’s really a personal preference. For me I use ag style , a bit cheaper and a whole lot easier to find in stores around me.
/ Flat face hydraulic connectors are better? #7
Wouldn’t it be great if there’s a simple “mash plate” style connector? It’s similar to trucks airline connection between the cab & trailer. 1/4” twist and it’s on regardless of residual pressure.
/ Flat face hydraulic connectors are better? #8
I'm not sure the glad hand style would hold up against hydraulic pressure. The air brake system only has about 135 psi in it.
/ Flat face hydraulic connectors are better? #9
True - I've had my ag style lock up too but a quick tap from a stick always releases it. I've never had the female side lock up, only the male side and they have that convenient little tip on it to gently wack it into compliance.
/ Flat face hydraulic connectors are better? #10
That's why I prefer to stay with that style. :thumbsup:
Tried and true, no complaints from me and thousands of "real" farmers. ;)
/ Flat face hydraulic connectors are better? #11
I know, that’s why I mentioned the word “similar”. There is a loader company that manufactures high end loaders with a unique connector where all the lines are attached effortlessly with one quick connection. One can dream...
/ Flat face hydraulic connectors are better? #12
No dreaming needed, they make them and are available on some tractor loaders as a option. A bit pricey though.
| Stucchi - Quick couplings
/ Flat face hydraulic connectors are better? #14
I have issues with my FF connectors under pressure too. In fact, I wrecked the seal on the female side trying to hook up my grapple after extracting it from the snow last week - now I'm not finding anywhere who advertises that o-ring for the 16028 couplers so I might have to go to a specialty shop and hope to get lucky. It oozes oil, so this is not a delayable repair.
I've been meaning to make a tool to connect the couplers with a square threaded clamp, because I'm tired of using my ad-hoc ratchet strap work-around. I relieve the pressure from the tractor side religiously whenever connecting or disconnecting (which is a PITA in of itself), but thermal conditions seem to always rear up on the implement end and make things annoying.
That said, I wouldn't want to go to the Ag style on my FEL. There's just way too much crap that ends up all over those fittings when I'm using a bucket or pushing through the brush without an attachment present (like mowing).
/ Flat face hydraulic connectors are better? #16
I have a friend who always has issues with his Bobcat's FF connectors holding pressure, even though the cat has a pressure relief switch. He made up a tool to fit over them and he pulls with the tool's lever and they go together pretty well. I'll have to take a picture and share it some time, it's simple and effective.
/ Flat face hydraulic connectors are better? #17
If you want to stick with Flush Face couplers, you could consider putting the connect-under-pressure type at least on the tractor. It doesn't completely solve the residual pressure coupling issues, but it helps. I use FF on my FEL 3rd function (1 pair on machine), ag style on rear remotes (2 pair on machine), Series B on backhoe and log splitter (1 pair) , and 10,000 PSI screw-on type on snowcat (8 pair on machine).
They all have advantages and disadvantages, the SERIES B are easiest to use. The 10,000 PSI are hard to clean and have an internal o-ring that eventually wears out, but they do connect under pressure. FF easiest to clean.
4HTF4-P-SET | Set of 1/2" Connect-Under-Pressure ISO 16028 Quick Disconnects
/ Flat face hydraulic connectors are better? #18
I didn’t know they exist. Nice to know!!!
/ Flat face hydraulic connectors are better? #19
Cleaning the ag style is simple, just use a can of starting fluid , a quick shot of starting fluid cleans them right out and cuts any grease and grime , dries in seconds.
/ Flat face hydraulic connectors are better? #20
Because everyone always has a can of that handy. I can clean the skid steer couplers with my hand although a rag is ideal.
2019 JCB 457 (A60462)
2R ROTARY HOE (A63291)
2015 Freightliner M2 106 AWD Altec AT37G 37ft. Insulated Bucket Truck (A60460)
2015 Freightliner...
Carryall 1700 4x4 (A61574)
Carryall 1700 4x4...
2016 Ford Escape SUV (A61574)
2016 Ford Escape...
2016 John Deere 6155R (A64119)
2016 John Deere...
