Flashlight recommendations?
/ Flashlight recommendations? #11
... myself just get cheap LED lights with most like a watch battery or 1 to 3 triple A batteries.
Same here. I have a couple of more powerful rechargeable Stanley LED lights, but I've got a dozen or so of these little guys. I keep one in the glove compartment, next to the bed, shelf by the door, basement utility room etc. etc.
Great light and always within reach when you need it. Light lasts a long time on AAA batteries, right angle so you an stand it up is very handy, belt clip (which you can use to hold in your teeth in a pinch!), and small enough to fit just about anywhere. Not a really bright light compared to the big guys of course but they get used just about every day for one thing or the other.
EDIT: Meant to say that this 41-4235 model can typically be had for around five bucks in stores like Sears or online. Makes buying in quantity practical. :)
/ Flashlight recommendations? #12
I have traditionally preffered maglite. What is involved in switching them to LED?
A friend has a OEM Maglite LED and it is a POS. Like a dollar store flashlight, you have to keep hitting the thing or angling it downward! Sad!
/ Flashlight recommendations? #13
You just have to buy a led bulb. I have a converted led and a factory led mag light. The factory led is considerably brighter.
/ Flashlight recommendations? #14
I've got half a dozen mini-mags between home and work. I like them but they eat batteries. I found a little LED conversion kit at home depot about a year ago and gave it a try. I do inspections, preventative maintenance and repairs on machinery, so it gets lots of use. Two AA's lasted almost 6 months after the LED conversion! It won't throw the beam anywhere near as far as the incandescent bulb, but for close up inspection, its white light is far superior. It makes me want to buy a mag light LED flashlight and test it out. Maybe Santa will bring me one this year... :D
/ Flashlight recommendations? #15
I've had an interesting observation regarding LED torches (what we call a flashlight = torch); while the LED light intensity is great, it upsets my horses if I need to check on them whilst dark.
As soon as I use a regular incandescent torch, they're fine... nothing is out of the ordinary. :confused3:
/ Flashlight recommendations? #16
I guess it kind of depends upon how often you will use it and what you expect out of the light. I've always used Makita rechargeable - my current one is - Lxt, 18V, lithium ion.
Out here where the only light, at night, is the stars & moon - I need a light that reaches out, scares all the evil critters and will easily cover the entire yard.
I use the light, at least, every single night when the dog & I venture out before we hit the sack. It will illuminate clear across the little lake - 900 feet - and can stop the coyotes in "mid-song". The coyotes like to sit on the cliffs across the lake and howl - their "song" echoes off the cliffs and can create quite a racket.
/ Flashlight recommendations? #17
Makita sells a few different models which one do you have? I have a lot of Makita stuff and a light like you describe would be useful.
/ Flashlight recommendations? #18
bigtiller -
I thought my description was fairly unique - until I just went on the Makita web site - they DO make quite a few that fit into my description.
Anyhow - the model is----- MKTBML185. I also see that they have reduced the price on the light. When I bought it I think the light, battery & charger were around $185. I would guess the three would be less now.
Other than the fact that the light is pretty far reaching - I appreciate rechargeable lights - I don't have to keep a supply of batteries and recharging is a simple one hour situation.
/ Flashlight recommendations? #19
Look at Surefire. They make some very good flashlights, although expensive. The last one I bought I got off of Amazon at a very good price, maybe $50. It has two light settings super bright and dimmer. Its LED and the battery life on the brightest setting in something like 10 hours and on the dimmer setting something like 40 hours. On the brightest setting, its almost as bright as what you would get out of a single headlight from a car. It almost boggles the mind on how much light it puts out. LED's were a big boon to the small flash lights. The earlier Surefire I had wasn't quite as bright and the batteries only lasted an hour. The LED's are brighter and use less power. The only drawback is the battery cost, it uses CR123 batteries. If you shop on line you can get these batteries for about $1 each.
/ Flashlight recommendations? #20
Mag Lites are great and I too converted an older 4D to LED, 1000 Lumens, great lite but heavy; it is in a mount under my truck seat now, waiting to be used.
In the mean time I purchased an Everyready two AA cell unit, small lightweight and BRIGHT.
It is suppose to be 380 Lumens but the effective lighting is as good as my 1000 Lumen Mag.
Rugged aluminum case, very heavy duty.
Purchased my Everyready from ACE Hardware and very happy with it and carry it in my back pocket, quick retrieve.
Check it out, you might find it ok for your use.
Forgot around $30.
Richardton 960 (A60462)
Richardton 960...
Vertical Steel Well Tank (A61570)
Vertical Steel...
2016 26ft T/A Dovetail Flatbed Equipment Trailer (A59228)
2016 26ft T/A...
Volvo L45H (A61307)
Volvo L45H (A61307)
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
GENIE SUPER LIFT CONTRACTOR (A60736)
GENIE SUPER LIFT...
