flashing message in switch panel what does it mean
/ flashing message in switch panel what does it mean #1
mopar
fort plain ny
John Deere 4310 ehydro mfwd
hi i'm getting a flashing message in my switch panel, 1 short then 2 long then 1 short then repeat ,what is it trying to tell me? book does not say only not to worry if it keeps doing it then contact dealer.
/ flashing message in switch panel what does it mean #2
Mopar,
This problem has been discussed before on TBN. From another post:
<font color="green"> Short, long, long, short or .--. is indeed the fault code for the mfwd sensor . If you have cruise control it will not function. The flywheel speed sensor is also the same part # as the mfwd sensor. So in my opinion the flywheel speed sensor could possibly fail, Their is an internal wiring problem inside certain speed sensors. Deere has corrected the problem with a fix as fail . This doesnt mean that everybody with e-hydros has to worry, not everybody will experience this. contact your dealer. The kit consist of both the mfwd and flywheel sensors and take about 5 minutes to install.
</font>
And another:
<font color="red">Note that the MFWD sensor error can also appear without their being a problem present. If you depress a pedal with the gear lever in neutral, then this error will appear after about 5 seconds. It could also apper if under a heavy load the hydrostatic transmission goes over relief and you hold it that way for about 5 seconds. Basically, if the microcontroller doesn't see a certain gear move while a foot pedal is depressed, then it will flag this error after about 5 seconds of this condition.
If your cruise control works, then you don't have to worry about your sensor. </font>
Hope this helps.
Jeff
/ flashing message in switch panel what does it mean #3
<font color="orange"> Hey Dude, I just had that one. restarting the tractor cleared it .</font>
/ flashing message in switch panel what does it mean #4
Mopar, i sent you a private message on this topic.
/ flashing message in switch panel what does it mean #5
On my 4310 with sync reverser if I shift it into forward or reverse and keep the clutch held in for some time, the little light will start blinking. I noticed it the first time it happened becuase when the little light starts blinking and you let out on the clutch the tractor doesn't move. I guess it is so if you sit there so long that you forget which way you were going you don't dump the clutch and run over something. I need to read that owners manual.
2004 Isuzu NPR 14ft. Box Truck (A61573)
2004 Isuzu NPR...
2001 International 4000 DT 466E (A60462)
2001 International...
2007 International 4300 Cab & Chassis 438418 (A62613)
2007 International...
2004 CATERPILLAR 416D BACKHOE (A60429)
2004 CATERPILLAR...
Kubota ZG222 (A60462)
2019 HINO 268 4X2 26FT NON CDL BOX TRUCK (A59911)
2019 HINO 268 4X2...
