flashing lights
/ flashing lights #1
Bever22
I had a weird thing happen today. The 2310 was parked outside when I saw the signal lights start to flash. I went out and they stopped. They started to flash again and then start to alternate. I could hear the flasher making all kinds of weird sounds and the switch is in the off position. Any suggestions :confused: ?
/ flashing lights #2
More info please. Engine running? Flashers turned on? Ignition switch in on position?
/ flashing lights
Motor off, ignition off, lights off, flashers switch off. I just got done washing it and I thought maybe the flasher got wet. I just went out and tried it and it is all fine now after it dried for about 3 hours.
/ flashing lights #4
If you just washed it, or was in a driving rain there may be water in the light switch, or the connection to the wiring harness. It's a pretty common occurrence . Disconnect the plug from the wiring harness and apply some dielectric grease to the connectors.
/ flashing lights
Will do that, thanks for the help.
/ flashing lights #6
Always remember Rule #3562
If you do something, and soon after that something undesirable happens, undo what you did first. (i.e. dry it out and try it).
Glad that worked.
/ flashing lights #7
3 hours lucky you it took 3 days or more to dry out the switch on my BX23 after washing the tractor.
The 2310 and BX23 probably use the same switch.
/ flashing lights #8
My freightliner does the same thing,in a heavy rain the clearance lights come on. I had to make a cover for fuse box, the rain dripping thru the roof lights onto windshield inside the cab would drip into the circuit breakers in fuse box. plowking
/ flashing lights
They worked all day today, seems to be ok now. :D
2013 FORD F-350 SUPER DUTY (A65643)
2013 FORD F-350...
2010 Doyle 32ft Tender Trailer - Kubota Diesel - Stainless Steel Augers - Recently Refurbished (A61307)
2010 Doyle 32ft...
2008 Chevrolet Silverado Pickup Truck (A62613)
2008 Chevrolet...
CASE INTERNATIONAL 5240 TRACTOR (A63291)
CASE INTERNATIONAL...
25' Flat Fold Cultivator (A66408)
25' Flat Fold...
2017 Ford Explorer AWD SUV (A64557)
2017 Ford Explorer...
