flashing lights
/ flashing lights #1
Bever22
I had a weird thing happen today. The 2310 was parked outside when I saw the signal lights start to flash. I went out and they stopped. They started to flash again and then start to alternate. I could hear the flasher making all kinds of weird sounds and the switch is in the off position. Any suggestions :confused: ?
/ flashing lights #2
More info please. Engine running? Flashers turned on? Ignition switch in on position?
/ flashing lights
Motor off, ignition off, lights off, flashers switch off. I just got done washing it and I thought maybe the flasher got wet. I just went out and tried it and it is all fine now after it dried for about 3 hours.
/ flashing lights #4
If you just washed it, or was in a driving rain there may be water in the light switch, or the connection to the wiring harness. It's a pretty common occurrence . Disconnect the plug from the wiring harness and apply some dielectric grease to the connectors.
/ flashing lights
Will do that, thanks for the help.
/ flashing lights #6
Always remember Rule #3562
If you do something, and soon after that something undesirable happens, undo what you did first. (i.e. dry it out and try it).
Glad that worked.
/ flashing lights #7
3 hours lucky you it took 3 days or more to dry out the switch on my BX23 after washing the tractor.
The 2310 and BX23 probably use the same switch.
/ flashing lights #8
My freightliner does the same thing,in a heavy rain the clearance lights come on. I had to make a cover for fuse box, the rain dripping thru the roof lights onto windshield inside the cab would drip into the circuit breakers in fuse box. plowking
/ flashing lights
They worked all day today, seems to be ok now. :D
2013 PETERBILT 367 (A65643)
2013 PETERBILT 367...
2010 Doyle 32ft Tender Trailer - Kubota Diesel - Stainless Steel Augers - Recently Refurbished (A61307)
2010 Doyle 32ft...
2016 WESTERN STAR 5700 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2016 WESTERN STAR...
2007 Komatsu WA200-5 (A64047)
2007 Komatsu...
1992 International 8200 Spreader Truck, VIN # 1HSHEDPN2NH418329 (A65563)
1992 International...
2025 PJ CC162 T/A 16FT EQUIPMENT TRAILER (A59914)
2025 PJ CC162 T/A...
