flail
/ flail #1
njtom
Wayne
kubota mx5000
my mott 72 justs cuts to shprt with roller as low as i can put it . how can i raise the cutting height
/ flail #2
Hello NJTom,
First things first,
The flail mower MUST BE LEVEL when mowing. Use a torpedo level on the flat front edge of the flail mower or the gear box if it is a flat gearbox and then back the top link out until the bubble on the torpedo level becomes level. After that you can be assured of a good mowing set up. Also be sure that the lower links are equal in length.
/ flail #3
Make sure Three Point Hitch Lifting Rod stirrups are pinned to the Lower Links in the TOP pin holes, not the BOTTOM pin holes.
/ flail #4
Lengthen your top link so it lifts the front of the flail higher riding on the roller to the desired height.
/ flail #5
Hello NJTom,
First things first,
Level, or even with the tractor's rear axle? In other words, do your instructions assume that the tractor is on perfectly level ground (L/R) when leveling the mower?
