Flail
/ Flail #1
stevewilli
UK, south coast, on a cliff
I've just taken delivery of my BX2350 with mmm and rear flail. A quick question I wonder if anyone can answer for me. When I lower the rear pto to use the rear flail the mmm also lowers and consequently flattens everything before the flail; gets to it. Do I need to take off the mmm or am I just doing something wrong? Also, is there any adjustment on the flail as I've a lot of small hidden stones.Unfortunately, the guy who delivered everything didn't supply instructions for the flail.
Thanks
Steve Williams
/ Flail #2
I believe you need to raise the MMM up and then put it in the lock position w/ the cutting height knob.
Then you should be able to lower your 3-pt w/out lowering the MMM.
/ Flail #3
exactly. it may go done a little, but should lock into the first (highest) setting of the height adjustment knob. that's how it is on my bx, anyway.
amp
/ Flail #4
Steve: If your flail is like most, the rear roller will have position adjustment bolt holes. Then after selecting a cut height with that setting you use the 3pt. link length to roll the flail back on the roller. KennyV.
Kivel 42in Forks and Frame Mini Skid Steer Attachment (A64553)
Kivel 42in Forks...
TONUTTI 10 WHEEL HAY RAKE (A64278)
TONUTTI 10 WHEEL...
2007 Polar Dot 407 Insulated T/A Chemical Tanker Trailer (A64194)
2007 Polar Dot 407...
2022 EZ-GO ELITE...
Sunflower Yard Art (A64557)
Sunflower Yard Art...
2015 International WorkStar 7500 29Yd. Side Loader Garbage Truck (A64194)
2015 International...
