fixing my driveway for 1st time??
/ fixing my driveway for 1st time?? #1
WiJC
Wisconsin
kubota B7610
i have a 600' crushed limestone driveway. it was put in last summer when we built and is now showing some signs of settling etc. there are a few holes etc.
i have a box scraper that i plan on using to make it all pretty again /forums/images/graemlins/tongue.gif
my question is...is there a best time to do this moisture wise??
is it better to wait till it is bone dry? or is it better when it is at least a little wet?
thanks
John
/ fixing my driveway for 1st time?? #2
I wouldn't work on the gravel drive until after the frost is out and the high moisture in the gravel had a chance to drain away. Otherwise, I would expect something akin to mud.
Working the gravel before the bone-dry summer time is a good idea. I would do as the county tends to do with gravel shoulders, that is work it up after a good 1/2 inch or so rain. Then after working it up and spreading it evenly (mixing the fines in with the loose stones), tamping it down firmly before the surface dries out. Waiting too long to tamp it will just leave loose gravel on top, and they will skoot off to the side after a time with traffic. Tamping is done (by me) by driving the car back and forth until every bit of the drive is pressed down by the wheels. Any rain before tamping will wash off the fines and packing will not happen. Any appreciable drying (i.e. waiting to tamp until the following day or even later that same day) will cause drying and you will lose the benefit of the fines in packing the drive tight. Getting a good mix of fines and stones is not easy without the right equipment, and the best is a grader (better control of depth and better distribution of gravel mix without 'bumps' added. The worst piece (IMO) is a gravel rake. I don't know how a box blade will work but I would think not being able to angle it would mean a lot of uneven bumps across the drive. I would expect the box blade to be similar to using a bucket on the FEL. I like to back drag for final smoothing with my 7' snow plow blade.
TSURUM HSZ3-755 PUMP-1 PHASE INDUCTION PUMP (A62131)
TSURUM HSZ3-755...
2015 Ford F-250 4x4 Cab and Chassis Truck (A61568)
2015 Ford F-250...
UNUSED TAYLOR-WAY 5' BOX BLADE (A62130)
UNUSED TAYLOR-WAY...
2012 Dodge Charger Sedan (A61569)
2012 Dodge Charger...
207270 (A52708)
207270 (A52708)
2014 Ford Focus Passenger Car, VIN # 1FADP3F21EL104239 (A61165)
2014 Ford Focus...
