fixing a ding in cylinder rod
   / fixing a ding in cylinder rod #1
TimBuck2
Central Massachusetts
Kubota L4310 HST and Ford 841
I let a rock roll down the pile and hit the stabilzer cylinder rod on my backhoe. Something I tell my son not to do a dozen times everytime he gets on the machine.
What is the best way to deal with the ding so it doesn't ruin the seal?
I smoothed the rough edge with a file and was thinking of using JB weld to fill the divot, and smooth the epoxy with a file after it cures.
Any thoughts?
Can this be fixed at a hydraulic shop?
   / fixing a ding in cylinder rod #2
I doubt JB will stay in place and could get in the hyd. system and do some damage before getting to the filter. If it is a shallow ding polish it smooth and expect to get some leakage. I think it will eventually damage the seal or the leak will start to spray out when the ding gets to the seal.
You might call a shop and get their opinion.
   / fixing a ding in cylinder rod #3
Assuming you filed it so nothing is sticking up, sand it with some 600 grit paper and oil and live with it. It really should not be that big of a deal, certainly nothing that I would be concerned about if it was mine. We have several cylinders with that type of thing, it takes a lot of use before any seals would have to be changed.
Just my :2cents:
   / fixing a ding in cylinder rod #5
If you have filed it nice and smooth it will be fine shouldn't leak a drop. Check that the rod doesn't have a bend now.
Unused 2024 AGT H15 Mini Excavator (A59228)
Unused 2024 AGT...
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
2-Row Peanut Inverter (Chain Drive, PTO, 3-Point Hitch) (A56438)
2-Row Peanut...
2008 CAT 305C (A53317)
2021 New Holland C327 Compact Track Loader (A57024)
2021 New Holland...
2001 JOHN DEERE 310SG BACKHOE (A60429)
2001 JOHN DEERE...
