Chains fitting chains ? tensioners question (s)
/ fitting chains ? tensioners question (s) #21
On my old man's Massey Ferguson 135, we took a large washer (about 3" in diameter) and drilled 8 holes around it, then used old trampoline springs to hook in the chains and the washer. The homemade tensioner works like a charm and nothing rots. I may try this as well on my 7800. Since huricane Isabel went through, it seems as if I have an abundance of trampoline springs as well as a lot of bent up pipe. /forums/images/graemlins/frown.gif
Thanks to all of you for helping out !
Had to remove a few cross links , but eveything went well .
The worst part was dishing the tires out for more clearance .
Those bolts were TIGHT !
Only turned the air blue once ! Got the first tire done , came up and looked at the picture Henro ( Bill) posted .
Had the chains on wrong ! the part where the cross chains attach to was on backwards . the second chain went well and only tok about 10 minutes . Again, Thanks ! You guy's are the best . John
Landhonor 48" Galvinized Fence (A66408)
Landhonor 48"...
2008 Lincoln MKX SUV (A64557)
2008 Lincoln MKX...
40ft High Cube Shipping Container (A65583)
40ft High Cube...
(1) HD 24ft Free Standing Corral Panel (A65579)
(1) HD 24ft Free...
2016 JOHN DEERE 7210R TRACTOR (A64280)
2016 JOHN DEERE...
2250' of 5" Tile (A66408)
2250' of 5" Tile...
