First Yanmar
/ First Yanmar #1
Jack Jr
yanmar 1500D4whl
Hello Everyone, Just bought a 80 1500 Deisel 2cyl 4whld, The 3 point wont stay in the up position for more than 2 min?, any quick fix?, thankyou, jack, Plus I sure would like to see what these green things looked like when it was new!?, Ide like to Restore, Thankyou, jack, In Oregon
/ First Yanmar #3
:welcome: to TBN fellow Oregonian! :thumbsup: My assumption on the 3 point hitch is a leaky hydraulic valve or a bad seal around the piston. Does it lift a considerable amt. of weight off the 3 point hitch or is it weak? My 3 point hitch on my 169D was very weak and it ended up being a $4 O-ring that goes around the piston and seals off pressure inside the cylinder. The cylinder is directly under the seat. It is a pretty simple repair, I did it in 1 day including locating the new O-ring. :) As for paint on your Yanmar, it came in either red or green from the factory. Yours appears to be originally green but I am not sure where you could get an exact match to it. Yanmar Tractor Parts - Shop Online sells exact match Yanmar red paint if you would like a pretty red tractor. Either way, welcome to the forum, glad to have you aboard!. :thumbsup:
/ First Yanmar #4
The picture you posted actually is a 155D, not a 1500D, that is good. For parts, check out this link.
http://www.hoyetractor.com/mm5/merchant.mvc?Screen=CTGY&Store_Code=HTE&Category_Code=155
The 155D is a domestic Yanmar which means it was intended for the U.S. market. The 1500D was a grey market tractor which means it was intended for use in Japan, not the U.S. Parts availability is probably about the same, a lot of 1500's have been imported here.
/ First Yanmar
Hey Thanx!, Yep it was Green, many coats of paint brushed on it through out the years living over at the Coast, Boy Im glad they atleast did the paint brush action!! Still pretty rough, but could be worse, 3 digit hr meter reads 43.5?, Hoses are really cracked bad, 1 leaks, but all is good, Im happy, I think I might sell my Wheelbarrow!!:thumbsup:, Jr
/ First Yanmar #6
The hour meter likely rolled over at 999.9 so it could have 1043.5 hours or 2043.5 hours. Does the hour meter work? Mine didnt when I got my tractor so i ordered a new cable from Hoye and replaced it myself. Not the tach. and the hour meter work great. :thumbsup: I would highly recommend replacing the hoses, cracked hoses will eventually fail and hot hydraulic fluid isn't good for your skin. Safety first at that. :)
2018 CATERPILLAR 259D SKID STEER (A65056)
2018 CATERPILLAR...
2020 Chevrolet Tahoe SUV (A66738)
2020 Chevrolet...
2011 MAGNUM TRAILER LIGHT PLANT (A67714)
2011 MAGNUM...
1998 TRAIL KING TK70HT HYDRAULIC TAIL TRAILER (A67714)
1998 TRAIL KING...
PORTA POTTY (A68842)
2007 INTERNATIONAL MAO25 SERVICE TRUCK (A66091)
2007 INTERNATIONAL...
