Buying Advice First Tractor
   / First Tractor #41
First tractor was a 1962 Farmall 504 diesel. I put a new Koyker loader on it in 2008? Still have that tractor.
CT
   / First Tractor #42
I am looking for 4wd tractor with a loader.
I have just under 9 acres, about half wooded, and would like to run the following attachments:
  • Tiller
  • Wood splitter
  • Box blade
  • Wood chipper
I believe I need 20-25 HP at the PTO to run the tiller.
Eventually I may want to use other attachments so would prefer to not limit myself, but I don't have enough knowledge to know how to mitigate that.
I would prefer something old that can effectively/easily run a loader without custom work (welding up custom brackets, third party hydraulics, etc).
The reason I want to go with something old is price, I don't have $35K+ to drop.
The flip side to buying used is that you need mechanical skills to keep them running (more so than with a new one). Sadly, I am not gifted in that way. As others have said, you picked a bad time to want a used tractor. I am going to buy new.
   / First Tractor #43
For non-commercial use, I'd argue the only skills needed to keep a solid 80s-90s vintage diesel tractor going are the ability to change fluids, replace filters, and find/grease zerks. That's been my personal experience over the last year and a half with my two fords and around 600 hours of not exactly easy work. Similar situation for the old man I work with and his deeres over the last 5 years.
   / First Tractor #44
Maybe add skills to store it out of the weather. :cool:
You are correct, the old girls run pretty much trouble free if you do what you describe.
2012 MACK CHU613 (A58214)
2012 MACK CHU613...
2022 Kubota RTV-XG850 Utility Cart (A56857)
2022 Kubota...
2016 Fiat 500X AWD Hatchback (A56859)
2016 Fiat 500X AWD...
2015 Ford Taurus Sedan (A56859)
2015 Ford Taurus...
1995 Freightliner FLD120 T/A Wet Kit Day Cab Truck Tractor (A55973)
1995 Freightliner...
ST225/75R15 Trailer Tires (A55788)
ST225/75R15...
