Remember you have poor braking with a load in the bucket and your going down hill, so be in 4wd if so and have a hand of the loader control ready to take the load off the bucket,,,watch lifting when lifting something wheel you are off level, it can lift a front wheel quick as I found out when I got off . I pulled the mat when new, painted the floor and bolts etc, then used acf 50 on the rad ,frame etc, and painted the frame bolts or bare areas.then sprayed lps on the under frame, I put 3m clear tape on the side of the floor to keep the boots from scratching it.and on the contact area between the mat and the floor boards for wear proofing
