first time plowing with ck35
/ first time plowing with ck35 #1
chuck172
Platinum Member
N.E, Pa.
Kioti DK40SEH, Ford 4500TLB, Ford 8n
I rigged up my kioti ck35 with a frame mount 7.5 fisher plow recently, thought I'd share my comments. I'm using the loader arms to lift the plow, remote to angle it. Frame mount. All I do is remove the front bucket two pins to connect, and sling the plow.
I have aquiline chains for the rear tires. I didn't put them on yet. The tires are filled with rimguard, and using a back blade for counterweight.
We go over a foot of extremely wet snow. Very heavy.
I just can't believe how the tractor plows! Like a tank. No slipping, sliding. It just digs in and pushes. I have to say way better than my F250.
Only one snowfall and I trust this setup. I wouldn't be afraid to plow 2' at a clip. Way better than I expected. It'll be unstoppable with the chains.
/ first time plowing with ck35 #3
Chuck,
Glad your plow setup is working for you.
Just came in from plowing a few driveways. The blacktop ones are a breeze to plow with the PA blade. But I sure wish the ground was frozen. The plow shoes dig into the gravel drives and leave shoe trenches.
/ first time plowing with ck35 #4
Glad things worked out great for you . If you get a snow packed area you will notice a big difference in the pushing ability as I am sure you are well aware of after using your f250 . The chains will be of great benefit then . It will be interesting to see if the tractor pushes to one side easier than the 250 when blade is at an angle on some slippery surfaces . Keep us posted how things work out for you . Pictures of set up would be great
/ first time plowing with ck35 #5
I have a Plow on my CK35 as well, with a rear mount blower it's a great combination for snow removal.
Post a picture Chuck, let's see what your beast looks like all dressed up!! 001.jpg
Unfrozen ground under the snow was a problem. I kept a very light strain on the plow lift so the shoes wouldn't dig in. The fisher plow has a bottom trip. Three springs. I forgot to mention I also have the crossover relief valve.
This morning I had some frozen piles that were banked the day before. I just passed through like butter. I'll post some pics. next time I have the plow on. I changed over to the bucket for working on the down trees from the storm.
/ first time plowing with ck35 #7
Hey Tractor Tom, is that a fan mounted inside your cab on the glass? If so, where did you get that fan with the suction cup?
/ first time plowing with ck35 #8
Gotta love it when plan comes together. :)
Yep..keep those banks push back.
/ first time plowing with ck35 #9
Hey Joe, it's a fan from Canadian Tire $30, I think Tractor Supply sells something similar. Suction cup, It has oscillate on / off, and has a high / low fan speed switch, Cig lighter plug in. I haven't plowed in cold enough weather to know if i really need a fan or not, but i figured better safe than fogged up. So far the Suction cup has stayed put as I've worked around the yard.
/ first time plowing with ck35 #10
You'll need it, I'm sure of it. My CK30 with Kioti cab fogged something fierce. With the DK, I use the A/C to cut the humidity level in the cab, but it still fogs till I get it really well warmed up. I have a similar fan from Canadian Tire, mine has a clamp end. Used it in the CK and now in the DK.
/ first time plowing with ck35 #11
Thanks Tom. I'm thinking of adding one in mine.
Case 2090 Tractor (A66285)
Case 2090 Tractor...
1995 Peterbilt 379 Tri-Axle Dump Truck (A61573)
1995 Peterbilt 379...
2022 EZ-GO ELITE...
2018 Ford F-250 4x4 Ext. Cab Pickup Truck (A64194)
2018 Ford F-250...
Star (A64557)
Star (A64557)
2011 Kia Sorento SUV (A64557)
2011 Kia Sorento...
