First Rollover!!
/ First Rollover!! #1
MFL
Chatt Hills, Georgia
Kubota B7800
Evening Guys,
Thought I'd show you how my afternoon went.
/ First Rollover!!
2nd
/ First Rollover!! #3
MFL
Sorry to see that /forums/images/graemlins/shocked.gif
Are you OK? Hope so!
How did you put it on its side? Full loader up to high?
/ First Rollover!!
Waiting for the guy whose pulling stumps for me to get me upright with his bulldozer.
In the meantime, how about some tips on the recovery process. I'll drain the oil, pull the points, check all fluids, anything else I should know about before I try and start her up again?
/ First Rollover!!
Thanks, I am. I was wearing my seat belt, and all things considered, it was a pretty gentle ride! /forums/images/graemlins/blush.gif The bucket wasn't high, but probably higher than it needed to be. I was filling in some ruts on a new road we cut to the back pasture, and on the 7th run, I got too close to the mud! /forums/images/graemlins/frown.gif /forums/images/graemlins/frown.gif The front left wheel just disappeared into the mud. My first reaction was to try and reverse, but that proved useless. I then thought to lower the bucket and use it to stabilize the front end, but by the time the brain kicked in, I was already on my side. /forums/images/graemlins/blush.gif /forums/images/graemlins/frown.gif /forums/images/graemlins/blush.gif.
/ First Rollover!! #6
Sorry to see your tractor on its side. Are your rear tires loaded? If it were me, I'd get it right side up ASAP, even if it meant paying someone. Check the coolant level, as well as the tranny and front diff. Did you loose any fluids? Oil, fuel, antifreeze, trans fluid, etc
/ First Rollover!!
JJT,
Unfortunately, I have fuel and oil dripping out now. I don't see any hydro fluid, but that could just be because of the position. I'll send an update as soon as I have her back up.
/ First Rollover!! #8
Sure appears you need some more ballast on the rear end. PHD won't do the trick, it appears. And first instincts to lower the FEL are very helpful to know when the rear wheels leave the ground. To me, that is sometimes not instinctive enough, but has been a 'saving' factor for me several times.
Appears to be a "lay over" and not a Rollover. I know, it's a technicality, but hey, a rollover is 'over'. I don't think you should find too many things seriously wrong (at least I hope not). But checking the fluids and topping them off, after letting it set upright on all fours should get you going again.
Glad no-one was hurt.
/ First Rollover!!
Beenthere,
Thanks! You're right, I was asking for trouble! /forums/images/graemlins/blush.gif PHD was completely the wrong thing to have on the back end. Trying to do too many things in one afternoon, and found the perect compination of things to teach me better!! You're also right about the layover. Actually, it was more of a squishover. The mud laid me down pretty gentley. I guess it's the tractor gods giving me a smack in the back of the head. Not too hard, but enough to teach me a lesson. Anything specific that you know of that that might be damaged from having the engine/tranny sit on its side like this??
/ First Rollover!!
beenthere,
The rear tires are loaded btw. Supposedly 300lbs of windshield washer fluid. Obviously not enough to make a difference this time.
2016 Ford Explorer AWD SUV (A59231)
2016 Ford Explorer...
2022 RAM 2500 HEAVY DUTY (A55745)
2022 RAM 2500...
2019 FORD F-150 XL EXT CAB TRUCK (A59823)
2019 FORD F-150 XL...
2023 CATERPILLAR 304 EXCAVATOR (A62129)
2023 CATERPILLAR...
2005 GMC Canyon (A57148)
2005 GMC Canyon...
2014 Crossroads RV Elevation T/A 5th Wheel Toy Hauler Travel Trailer (A59231)
2014 Crossroads RV...
