First oil change workmaster 75 2022 what in God's name
   / First oil change workmaster 75 2022 what in God's name #41
You want to talk about just plain luck - knock on wood, etc, etc. Who ever thinks to check on "filter change difficulties" when purchasing a new tractor.
The oil filter on my M6040 is tucked up and in a fairly tight location. I can still get a band filter wrench around it and quite easily install a new one.
I'd be pissed off, to no end, if it were something like RADIUM's situation.
I DO hope you find a good solution.
(y)
   / First oil change workmaster 75 2022 what in God's name #43
I just jam a large screwdriver through the case, let it pee out in a pan, lever it off and replace with a new one. easy-peasy.
PREDATOR 3500 W GAS GENERATOR (A58376)
PREDATOR 3500 W...
2014 DODGE RAM 2500 (A58214)
2014 DODGE RAM...
Case 1020 25ft Draper Head (A56436)
Case 1020 25ft...
IRanch High-End Mini Golf Cart (A57149)
IRanch High-End...
RING 2 STARTS HERE @ 9:15 AM (A58375)
RING 2 STARTS HERE...
Unused SDJ-4000 9,000lb Two-Post Electric Auto Lift (A55851)
Unused SDJ-4000...
