First issue with the Supertrak
/ First issue with the Supertrak #1
QwikDraw
Platinum Member
North East
Timber King TK711
I posted this over at the construction section too.
I had someone operating it and the drive motor speed sensor got torn off. I replaced it temporarily but the alarm will not shut off. A friend of mine said it could be a "hard fault" and would need the ecm reset by the Cat mechanic..
Does this sould right? any way of resetting the fault with out the computer? Take wire off the battery?
I am looking at this...is it what I need to reset myself?
CAT ET,Caterpillar Electronic Technician,CAT Communication Adapter
/ First issue with the Supertrak #2
Ted, a lot of times the computer can be reset by simply removing the negative battery cable. (do not try while running. That will fry your computer) This may or may not work in your situation depending on what kind of fault code was triggered. Worth a try though.
/ First issue with the Supertrak #3
Had mine get ripped off a couple times. I built a gaurd to go between the frame an the final never got pulled again. My machine was still under warranty the few times it got ripped off so can't help u reset the computer but dirtroad is right u can reset it by disconnecting the negative side on the battery.
Thanks guys, I will try that first.
ROANOKE LONG ARM DITCH BANK MOWER (A63291)
ROANOKE LONG ARM...
Mobile command center (A61573)
Mobile command...
2004 FORD F-350 SUPER DUTY (INOPERABLE) (A58214)
2004 FORD F-350...
2016 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A61573)
2016 Chevrolet...
2003 Chevrolet Kodiak C4500 Flatbed 503372 (A62613)
2003 Chevrolet...
2013 Ford Taurus Sedan (A61574)
2013 Ford Taurus...
