~~ First Flat TIRE on My BX . **
/ ~~ First Flat TIRE on My BX . ** #1
LBrown59
Super Star Member
First organized permanent settlement in the northw
2003 Kubota BX1500/2004 Kubota Bx23/2005 Kubota BX1500
Not bad for 3 BXs and 6 years of owner ship.
Here's the thing that sorta suprised me .
When I removed the front wheel on the 2003 BX1500 there was a steel spacer between the rim and the hub.
It looked to be about 1/4 to 3/8 inches thick .
Anyone on TBN have such a spacer on their BX1500 ?
I bought the tractor used and am inclined to think a previous owner added the spacers.
That is the trouble with buying used / u don't know what some one else did to it.
/ ~~ First Flat TIRE on My BX . ** #2
i had repeated flats with my BX. Put in tubes and all was well.
/ ~~ First Flat TIRE on My BX . ** #4
I just had the second flat on my BX 24. Not sure what happened but the tire split in the middle of the sidewall and the steel wire was showing thru. I don't think a tube will work here as I figure if I can see the wire on the outside there is likely some showing on the inside and that rules out using a tube. I checked at the dealer and the price of the new tire is $77. Seems like a lot for an oem tire when I can get a good one for about $80. What do you all think?
/ ~~ First Flat TIRE on My BX . ** #5
Anyone on TBN have such a spacer on their BX1500 [FONT=Arial Black[/QUOTE]
I have had a couple of BX's, but not a 1500 series. No spacers for me. Since you have another one pull a tire and let us know what you find.
/ ~~ First Flat TIRE on My BX . ** #6
My front tires went flat, realized after the second time I inflated them the needle valve in the valve stem was leaking.....tightened the needle valve and no more flats. Air was leaking very slowly you might want to check that first
/ ~~ First Flat TIRE on My BX . ** #7
After my third rear tire flat the first summer... I had the tires foamed filled and never looked back...
/ ~~ First Flat TIRE on My BX . ** #8
My right front has started leaking just this last 2 weeks. Will hold for a few days and then be partially flat for the next day. Weird.
/ ~~ First Flat TIRE on My BX . ** #9
My right front has started leaking just this last 2 weeks. Will hold for a few days and then be prtially flat for the next day. Weird.
Just like my BX2660. I keep the air compressor next to the Bota, and fill the front right tire if it's been more than 2 weeks since last use. The front left had the same problem, actually worse, but I put a tube in it last year. It's been ok ever since. One of these days I'll tube the right one.
EZ-GO Electric Golf Cart (A60463)
EZ-GO Electric...
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
2004 INTERNATIONAL 7400 20FT TANDEM AXLE FLAT BED (A59906)
2004 INTERNATIONAL...
DSP 900 Balancer with Split Weight (A61307)
DSP 900 Balancer...
EZ-GO Electric Golf Cart (A60462)
EZ-GO Electric...
2018 FORD TRANSIT VAN (INOPERABLE) (A60736)
2018 FORD TRANSIT...
