First attempt at scratch start tig welding
   / First attempt at scratch start tig welding #1
City Farmer
Platinum Member
Chesterfield, Mi
Ford 3000, 4400 & 4500TLB Case 830 Case 350 dozer
I put together a scratch start tig for my Miller thunderbolt ac/dc stick welder today. These are my first and second beads with a tig torch. I'm using 100% argon set at 15. It seems to run ok once it gets hot but the tungsten gets worn out really quick. Any tips for that? Here's a couple pictures. Any tips or recommendations would be appreciated. The second & third picture are the front and back of the same weld, I never welded the back side. I think there was to much heat to make it blow through like that.
   / First attempt at scratch start tig welding #2
Might be hot.. What size tungsten, what kind of tungsten, (what color of band) and what amperage? I use lanthanated, and they last well, as long as I don't dip it in the puddle,, (which I still do more than I care to admit):)
Oh, also did you have the metal perfectly clean? no rust or scale in the welding zone?
   / First attempt at scratch start tig welding #3
Maybe is the type of tungsten you are using??:confused3:
   / First attempt at scratch start tig welding #4
Oh, you have to clean the metal better before welding!
I'll give it another try tomorrow on some new pieces that are all cleaned up and repost.
   / First attempt at scratch start tig welding #7
TIG doesn't fill as much as other welding processes. It looks like you're trying to fill too much at a time. TIG is usually used for small really neat welds on thin material. Using it on thick material is a waste of argon. If you're burning the tungsten up are you on straight polarity?
   / First attempt at scratch start tig welding #9
Tig is used on thick steel all the time, its not a waste of argon.
Straight polarity is what it should be on, if the tungsten is eroding then its on reverse polarity or there is a shielding problem. Don't know if that is what you meant or not, just don't want the OP confused.
   / First attempt at scratch start tig welding #10
yeah, there is no way to be confused by "straight polarity" and "reversed polarity" That is SOOOO descriptive. As if the OP would just inherently know what is "straight" and what is "reversed"..
Why in the wide world of sports do professional welders continue to use this totally useless description of polarity settings.? Can you not understand if a new person to welding does not know enough to set the polarity correctly, how in the world is he going to know what is "straight" and "reversed"? HUH?
2024 Xpro Mini Dirt Bike (A50324)
2024 Xpro Mini...
Brown 6' Disc Harrow (A50123)
Brown 6' Disc...
ALLISON TRANSMISSION (A53843)
ALLISON...
2010 Ford Crown Victoria Sedan (A51694)
2010 Ford Crown...
2015 TOP HAT TRAILER 20 FOOT UTILITY TRAILER (A53843)
2015 TOP HAT...
2012 Ford F-450 Knapheide Service Truck with Liftgate (A51692)
2012 Ford F-450...
