Fireplace damper removal
/ Fireplace damper removal #1
johns_dmax
Mustang OK
NH Boomer 55, Bobcat Toolcat 5610
Our fireplace got hit by lightning in a storm a few weeks ago. When the guys came out to pull off the damaged brick they suggested I try to open the damper. Hadn't thought of that and of course it won't open. They said "its just sitting on a ledge just wiggle it loose". It not just sitting there but has pins going into each side of the damper frame. I tried to pry it over to one side to see if it would clear but no, still stuck. Any one have other ideas on getting this out? The house is only 4 years old so I don't really want to replace the damper. Ideas please?
/ Fireplace damper removal #2
I use to do alot of chimney work in my contracting business so I'll try to help, the damper sits on the frame and hinges on a couple of cast ears, if it's like all the ones I've ever seen in the last 30 years the pins should just be for the handle/lever linkage, you can start by removing the handle by taking the pins out, then try and push up on the damper on the upper edge, it hinges on the bottom edge.
if you can get it to budge a little upwards an inch or 2 then you can slide the bottom/back of the damper forward off the back of the frame, then when it's off the back you will still have to slide it to one side or the other to get the back corner to drop down. you'll have to get under it to do all of this so be real careful cause your gonna get a lap/face/head full of brick and mortar.
you might have to use a couple of pry bars to move that damper with the rubble on top. it's possible that it's so wedged in there that it's not gonna move. though I've never seen this and have done a few lightning jobs.
Worse case #1 check your dampers style/size with a new one at the local mason supply yard, with your home being so new they may still have the same one and you may be able to get just a door since the frames sometimes come in broken on account that they are a thin casting, then you can break the damper with a heavy hammer it's also cast and will break pretty easy.
Worse Case #2, you'll have to open the chimney from the outside above the height of the damper to remove the rubble. if this is an insurance job then the adjuster should be made aware of the problem.
Good Luck, JB.
Thanks for the info, I'll take another look at it. If I have to replace it I'll probably go with a top mount damper and just cut the thing out. Don't think we want to take out that much brick. The wife already doesn't like how the new doesn't match the existing and its way up at the top of the chimney. Thanks again.
2016 Ford F-250 Warner Service Truck (A61573)
2016 Ford F-250...
2012 Ford F-150 Harley-Davidson Edition - 48k miles (A63118)
2012 Ford F-150...
2004 Chevrolet Tahoe 4x4 (MPV), VIN # 1GNEK13Z24R318274 (A61165)
2004 Chevrolet...
2022 Ditch Witch C16X 36" Dig Depth Trencher (A64047)
2022 Ditch Witch...
2007 Toyota RAV4 SUV (A61574)
2007 Toyota RAV4...
2006 John Deere 1790 Planter (A63109)
2006 John Deere...
