Fire starter, what is your recommendation
   / Fire starter, what is your recommendation
I found a old Zippo tonight from my smoking days…..
I might buy some lighter fluid and see how that works
I have one of those blue flame torches, they're really nice and compact... myself for my burn pile I have a weed burner torch with a propane tank on a hand truck and a flint igniter on a rope attached to the handle...
I have a propane tank weed torch, but hauling it around 20 acres is a pain in the a..
   / Fire starter, what is your recommendation #23
I don't kmkw
I bought mine for fires in the woods and starting the wood stove. The drawback is that I have to fill it every few days whether I use it or not.
   / Fire starter, what is your recommendation #24
I use an old egg carton and a single wooden match
Best fire starter is using nice hard maple logs as overnighters and using the coals in the morning
   / Fire starter, what is your recommendation #25
For brush piles, I have always used a "fire box". A cardboard beer case, stuffed with wood chips, branches used paper towels and soaked in diesel or lighter fluid. It sits on a downwind spot and a long wood stove match gets it going.
I always forget the bics or zippos, matches are in abundant supply here though. LOL.
   / Fire starter, what is your recommendation #26
I used to smoke a pipe years ago. I had a Butane lighter that I still carry in my pocket long after I gave up the pipe. I use it almost every day for things like starting brush fires, fireplace, stove, burn barrel, etc.
Easily refillable and lights every time.
   / Fire starter, what is your recommendation #27
For hard to light brush piles a water fire extinguisher filled with diesel fuel. Just make sure it's clearly marked as fuel for obvious reason.
Clearly marked? How about a total makeover?
I can just see some visiting kid catching his pants on fire, and his Mom grabbing the nearest fire extinguisher, not bothering to read the huge lettering marked all over it. She sprays the kid down thinking she has saved him, only to find out that it was fuel and she killed him. I can just see the look in the attorneys' eyes as they start calculating their share of the millions she will sue for!
I would look for something else to make a fire starter out of. If I had one, I would dispose of it, simply because when we get older, we get forgetful and markings we used may not last as long as the original paint. You know what is in it, it is clearly marked (or not clearly over time) and yet someone still mistakes it for an extinguisher in a panic. It is not going to work out well for anyone...
David from jax
   / Fire starter, what is your recommendation #28
I bought the butane lighter that is refillable. So far it’s lasted me a year or more. You can turn the flame up and down and I have it most of the way turned down. I’ve had lousy luck with the throw away Bic type lighters.
   / Fire starter, what is your recommendation #29
David from jax
Only pressurize it when I'm using it and pressure removed when not in use.
   / Fire starter, what is your recommendation #30
This is why they are called tragic accidents that might have been avoided if only....
Giyi 72" Grapple Bucket (A57149)
Giyi 72" Grapple...
FUEL CELL TOOLBOX COMBO (A58214)
FUEL CELL TOOLBOX...
2013 TYTAL CRUDE TRAILER (A58214)
2013 TYTAL CRUDE...
2019 INTERNATIONAL LT625 (A58214)
2019 INTERNATIONAL...
2017 Ford F-450XL (A57148)
2017 Ford F-450XL...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55315)
NEW HOLLAND 706 30...
