Fire starter, what is your recommendation
   / Fire starter, what is your recommendation #31
Rather than fire extinguisher, how about the air compressor pressurized brake cleaner can from HF? I wouod think 32 oz of diesel should be plenty
   / Fire starter, what is your recommendation #32
This is why they are called tragic accidents that might have been avoided if only....
The can spends its life outside where my wood processing area is probably 500 ft from the house with no pressure and rarely any fuel left in it when it's not in use. It's not even within eyesight of the house. The "if only" has been taken care of.
   / Fire starter, what is your recommendation #33
I guess I am just not in a hurry. I don't use any accelerants, I just use one of those Firestarters that look like a huge match. I start a small fire and slowly build it. After maybe 15 to 20 minutes of careful feeding I can start throwing stuff on in earnest. In my case I don't have a premade brush pile. I am cleaning up areas and feeding the fire as I clean.
Doug in SW IA
   / Fire starter, what is your recommendation #34
Old sometimes stale Gasoline and expired marine flares shot from a flare gun at a safe distance. If your a bad shot don't listen to me.
   / Fire starter, what is your recommendation #35
I have a propane tank weed torch, but hauling it around 20 acres is a pain in the a..
But then, usually, dont you have a loader tractor present when you start and monitor the early stages of the fire?
   / Fire starter, what is your recommendation #36
Doug in SW IA
This. If circumstances allow, it always works better to throw stuff on a fire than to try to get a pile to burn.
   / Fire starter, what is your recommendation #37
I also like those fire starters that look like a giant match to start fires in my fire place. Outside I use one of these.
   / Fire starter, what is your recommendation #38
Isn't DodgeMan's picture above just that above fire extinguisher with diesel in it? Just mounted on the guy's back. Jon
   / Fire starter, what is your recommendation #39
I used to use newspapers to help start small fires but the newspaper got too expensive so I canceled my subscription. I'll have to find something else. That paper was leaning so far left, I didn't believe most of what was printed.
   / Fire starter, what is your recommendation #40
I think better “tinder” and small twig prep is what is needed. Not a hotter better lighter.
Make some with a flint/steel/char cloth and you’ll figure it out.
UNUSED FUTURE 40" HYD TILTING BUCKET (A52706)
UNUSED FUTURE 40"...
JOHN DEERE 6000 HI-CYCLE GREEN TOP SPRAYER (A52708)
JOHN DEERE 6000...
2018 Ford F-350 Crew Cab Service Truck (A56858)
2018 Ford F-350...
Compressor (A55973)
Compressor (A55973)
2020 FREIGHTLINER M2 SERVICE TRUCK (A58214)
2020 FREIGHTLINER...
2016 Ford E-450 Passenger Bus (A56858)
2016 Ford E-450...
