Fire extinguisher
/ Fire extinguisher #1
Bob Ha
DFW, TX
NH TN75, Kubota M9960, Kubota M7040, NH T4.85
Just purchased a $20 fire extinguisher to mount somewhere on my tractor. Cheap insurance policy that could save thousands. I was thinking of mounting it on the ROPS but not sure... any suggestions. Where does everyone else have theirs mounted?
/ Fire extinguisher #3
The kind you would want for an electrical fire or a fuel fire is a dry charge. Powder and CO2. On your hay baler you might want a few water extinguishers.
Fire Extinguisher: 101
/ Fire extinguisher #4
In winter weather would one of those things freeze up and render it useless?
Dry chems won't freeze! Although the powder may settle & pack due to vibration on a vehicle. Won't hurt to turn it upside down & shake it occasionally.
I mounted mine on the ROPS, clamped to the post with two straps & long bolts; ~~ grnspot110
/ Fire extinguisher #5
A general purpose fire exinguisher that is rated to fight all three types of fires, wood and paper, electrical and flamable liquids is filled with a white powder and is pressurized with dry nitrogen. It will not freeze.
/ Fire extinguisher #6
that's where I mount mine.. on a rops upright. just use zipties to hold the oem bracket tot he rops.. or a band clamp.. etc.
/ Fire extinguisher #7
I mounted mine on the right side of the dash using large fender washers to give some backing strength to the plastic dash
/ Fire extinguisher #8
Two BC extinguishers, one on each side of the tractor and a large ABC extinguisher on the gooseneck transport trailer.
/ Fire extinguisher #9
hey.. that reminds me ( thanks ).. I can't remember if I put an extinguisher on my GN or not... needs to have one though...
soundguy
/ Fire extinguisher #11
Good point. I'm delaying a decision to obtain a couple of extinguishers about 2 years already :mur:
/ Fire extinguisher #12
i'm glad this post came up. i keep my f450 'toy getter' all full loaded ready to crank up, hitcht he gooseneck and head out to collect tractors I keep it ready with spare fuel, tools, winch, jack, air, extra rmaps.. lubes. irons.. tons of straps.. etc. anything I think I might need broke down on the side of some interstate in another state, or trying to get a finicky tractor loaded. one thing I had overlooked was a fire extinguisher... even had the first aid kit, maps and all.. flashlights..e tc..
glad it came up. I went and got the extinguisher tonight.. :)
soundguy
/ Fire extinguisher #13
I can see the value of having a fire extinguisher at the ready. I work in wooded and brushy areas. Any one have any problems with getting caught in the brush and have an inadvertent discharge? I am thinking of the BX24 fans that get damaged and wonder about how to keep something similar from happening to a fire extinguisher.
Take Care,
Doug in SW IA
/ Fire extinguisher #16
yep.. you want a good positive holder with a neck cradle, and a snap open body strap.. the lil flimsy ones won't hold up as well on an ATV like a tractor....
soundguy
/ Fire extinguisher #19
Mine is mounted on the Rops also, but not exactly. It is sitting in a piece of PVC pipe with a cap on the bottom that is long enough to protect it from most everything.(except a rollover? ?)
Davld from Jax
Bombarder Sea Doo GTI (A64127)
Bombarder Sea Doo...
2003 Proclaim Tanker Trailer (A64194)
2003 Proclaim...
2021 Sany SMG 200C-8 Motor Grader (A62679)
2021 Sany SMG...
2014 MAGNUM TRAILER (A68842)
2014 MAGNUM...
125 GAL TANK (A68842)
2002 FORD F150 EXTENDED CAB PICKUP TRUCK (A66091)
2002 FORD F150...
