Finnish mower blades
/ Finnish mower blades #1
EMS503
Harmony, NC
1960 or 61 MF35 Deluxe, 2008 Kubota L3940 GST
I have a Woods finish mower 72", I need to get new blades and have found two different style blades. One is a high suction blade and the other is a low suction blade. Does anyone know the difference between these blades?
Thanks John
/ Finnish mower blades #3
Thanks John
The difference, if I understand your question, is the amount of elevation of the lift fins. the high lift blades usually cut better, but won't last as long in a dusty environment. The low lift don't stir up as much dust under dry conditions.
Jim
JD5210. I raise the mower with my 3 point hitch and then set safety jacks under it, Just in case. Then I slide under the deck and use my air rachet to take the blades off. Thankyou for the links I will read them.
Jim if this is true I must have high lift blades because I only get a year out of them, The gravel driveway dosen't help either.
/ Finnish mower blades #5
Normally you will use the high lift blades. The low suction blades are for use in sand soils where the sand will scour the blades.
I lift my Woods with the 3-point, back the tractor up to the porch, then set the mower kicker wheels on the edge of the porch and set the tractor parking brake. Slide under it with a 1" socket on a breaker bar, then use a piece of unistrut to hold the blade while I loosen it...and these are reverse thread bolts, just in case someone diesn't know it.
/ Finnish mower blades #6
On a side note on removing the blades and reinstalling. I use to use a "cheater" pipe and ratchet but now just use an electric impact. Makes life easier when changing blades.
/ Finnish mower blades #7
This is the first year that we have been getting calls about mower owners trying China blades and having problems with them breaking across the center hole. They are inexpensive blades, however, they are missing the heat treat on some production runs. Always use OEM or Italian blades to avoid this problem. Ken Sweet
/ Finnish mower blades #8
I don't buy anything made of any metal produced in China that I'm not willing to throw away after the first use.
/ Finnish mower blades #9
I suggest you chock those rear tires...
2017 International Prostar 122 Day Cab (A62613)
2017 International...
2007 Ford Crown Victoria Sedan (A61574)
2007 Ford Crown...
86 (A63290)
86 (A63290)
2011 Nissan Juke AWD SUV (A61574)
2011 Nissan Juke...
500BBL SKIDDED FRAC TANK (A58214)
500BBL SKIDDED...
KBH PT 12 Row Liquid Fertilizer Applicator (A64119)
KBH PT 12 Row...
