finishing mower gearbox replacement
/ finishing mower gearbox replacement #1
geosigal
massey ferguson 253
has anyone replaced a woods finishing mower gearbox with a brand other than the expensive woods replacement?
specifically it's a woods rd8400 model finishing mower for which i need a new gearbox....
/ finishing mower gearbox replacement #3
Watch Wes Work over on YouTube posted a video the other day on rebuilding an old woods mower gearbox. Parts were either crazy expensive or no longer available for it. He did some DIY magic as is his custom.
/ finishing mower gearbox replacement #4
Changing out a finish mower gearbox isn't a big deal, "IF" you have plenty of metal fabrication tools and experience to use them.
Most gearboxes simply sit on a platform, so the height of the platform, the gearbox bolt pattern will matter. You will have output shaft dimensions issues, which leads me to want to buy a used gearbox with the pulley included. However, getting the pulley off can be an issue. (I have a couple Rhino finish mowers that I have NEVER been able to remove a pulley. The last time, I just installed a new Taper-Loc pulley.
I would look for a way to figure out what mowers those gearboxes were used on, and see if I could locate a used mower that the deck had rusted out on. Most finish mowers get parked for reasons other than a bad gearbox.
David from jax
1999 CATERPILLAR 312B EXCAVATOR (A52709)
1999 CATERPILLAR...
2008 Dynapac CA150D (A60462)
2008 Dynapac...
Year: 2017 Make: Ford Model: Fusion Vehicle Type: Passenger Car Mileage: 101,691 Plate: Body Type... (A55853)
Year: 2017 Make...
PALLET OF(3) CABINETS & (5)BOXES OF CARPET SQUARES (A60432)
PALLET OF(3)...
Case skid steer wheels and tires (A61306)
Case skid steer...
CATERPILLAR 305 CR EXCAVATOR (A52709)
CATERPILLAR 305 CR...
