finished winter cab
/ finished winter cab #1
emery
Western Mass
Kubota b9200
my idea of trying a golf cart cab on my tractor worked out just as I had hoped. It is almost a perfect fit and only cost $100 from Northern Hydraulics. It has zipper entry doors on each side and a zipper in each corner. The two front corners I left slightly unzipped to allow for FEL movement. The top is plywood 45"x59" with rounded corners and support by ROPS and front posts I attached to FEL frame using existing bolts.
The only real gaps are by the foot pedals and I will cut some carpet and drape it down over that area to keep most of wind out.
here is side view.
/ finished winter cab #3
Looks like you'll get the chance to check out your new idea sooner than you think. /w3tcompact/icons/wink.gif
Thomas..NH /w3tcompact/icons/wink.gif
/ finished winter cab #4
Now that is cool. I think for running in the snow to clear out a driveway or two this is pretty cheap! Looks like it will keep some of the cold off of you. No window wipers though.
Nuru
/ finished winter cab #5
I can't tell from the photos...is there a canopy on the tractor?
Tractor had no canopy but did have ROPS. I added meetal support up from bolted to FEL frame and then put plywood cut to correct dimensions 45"x59". I just used loops of wire to tie down plywood around rops and front support.
1998 Freightliner MT45 Step Van Food Truck (A64556)
1998 Freightliner...
2022 EZ-GO ELITE...
2014 Honda Accord Coupe (A61574)
2014 Honda Accord...
2015 Hyundai VC2530152 53ft. T/A Dry Van Trailer (A64556)
2015 Hyundai...
2022 SANY SY50U EXCAVATOR (A63276)
2022 SANY SY50U...
2008 KOMATSU PC78MR-6 EXCAVATOR (A65053)
2008 KOMATSU...
