Finished loader for old MTD tractor
/ Finished loader for old MTD tractor #1
blacksmith
I finished my loader for my 30 year old Dayton (MTD 990) GT tractor. Here are some pictures.
I removed my hand control and added a foot control. Check out the foot brake as I had to add a "U" piece so I could clear my big foot. I will paint the bucket and add a guard for the pump. I want to add power steering so I will look for a used steering valve.
I tested out the pump when I worked in 90 deg. heat for 2 hours without the oil getting too hot. I moved a lot of dirt in the two hours. The bucket comes off and on very easily with the quick disconnect feature on the loader.
/ Finished loader for old MTD tractor #2
Good job! Steer ok with a full load?
/ Finished loader for old MTD tractor #3
Looks good! I'm envious of your ability.
/ Finished loader for old MTD tractor #4
Nice Job!
I have an old MTD 16hp and have often thought a FEL would be handy..
It does steer hard with a full load and you have to be moving to steer but it gets the job done.
/ Finished loader for old MTD tractor #6
That looks great blacksmith!! what are you using for ballast?
Having a loader makes me wonder what, if anything, would I have accomplished at my place if I was FEL-less!! It is the single most useful attachment, for me, on my tractor!!
(The backhoe is number two. For tools my chainsaws are third on the list, followed by the wood splitter.)
/ Finished loader for old MTD tractor #7
Yep, great job.
Some rear-ballast hanging off the back may help stability and that steering issue.
Thanks for thr pics, good job.
My tires weight 50# each plus 50# of wheel weight. If I need more ballast I plan on building this weighted platform. It is made from 6"sq. tubing filled with sand and adding 1/2" plates as needed. It will be attached on my 3ph. I have all the material all I need to do is weld it together.
/ Finished loader for old MTD tractor #9
Thanks for sharing. Great job.
/ Finished loader for old MTD tractor #10
I have an 1,100 lb hoe on rear, some times it feels like I could use more- that weight box sounds pretty good to me..:)
/ Finished loader for old MTD tractor #11
See if you can get punch press rounds for scrap price... that makes it about 4 times heavier than a sand fill.
/ Finished loader for old MTD tractor #12
Is it still working ok? Any problems?
David from jax
sandman2234 ~~ I did have a problem with the tie rod bracket it broke off when I was hauling stone. I found out that the bracket was broken before because half of the crack was rusted. I welded it back together and it works fine. I do have a leak from one of the used lift cylinders. I thought that the seal was "OK" but under full pressure it is not. It is the front seal on the right hand cylinder. I do have more cylinders so I will rebuild one to replace it this winter. I'm having too much fun using it to stop and rebuild it at this time.
/ Finished loader for old MTD tractor #14
Blacksmith,
Where did you get the steel hydraulic lines made?
hogi ~~ The tubing I used was scrap pieces from work. It is made with nickel so it will not rust and it is stronger than regular steel tubing. I bent the angles myself and either welded or used "Swagelok" fittings or made my own. I used 3/8 tubing because it was free. I bought my hoses and some fittings from surpluscenter.com or northerntool.com.
/ Finished loader for old MTD tractor #17
could u get some sizes of ur loader and mounnts, what type of pump did u use and what did u use for a reservoir. why asking so much is cause i got a tractor identical to urs only it is labeled farm king. but is a 990
2014 FREIGHTLINER CASCADIA (A65643)
2014 FREIGHTLINER...
White Oak Slabs (A65640)
White Oak Slabs...
2017 Cat 316FL Excavator (A62679)
2017 Cat 316FL...
Club Car Golf Cart (A66285)
Club Car Golf Cart...
(1) 30 Yard Roll Off Dumpster (A65579)
(1) 30 Yard Roll...
2018 Ford Explorer AWD SUV (A64557)
2018 Ford Explorer...
