Finished loader for old MTD tractor
/ Finished loader for old MTD tractor #1
blacksmith
I finished my loader for my 30 year old Dayton (MTD 990) GT tractor. Here are some pictures.
I removed my hand control and added a foot control. Check out the foot brake as I had to add a "U" piece so I could clear my big foot. I will paint the bucket and add a guard for the pump. I want to add power steering so I will look for a used steering valve.
I tested out the pump when I worked in 90 deg. heat for 2 hours without the oil getting too hot. I moved a lot of dirt in the two hours. The bucket comes off and on very easily with the quick disconnect feature on the loader.
/ Finished loader for old MTD tractor #2
Good job! Steer ok with a full load?
/ Finished loader for old MTD tractor #3
Looks good! I'm envious of your ability.
/ Finished loader for old MTD tractor #4
Nice Job!
I have an old MTD 16hp and have often thought a FEL would be handy..
It does steer hard with a full load and you have to be moving to steer but it gets the job done.
/ Finished loader for old MTD tractor #6
That looks great blacksmith!! what are you using for ballast?
Having a loader makes me wonder what, if anything, would I have accomplished at my place if I was FEL-less!! It is the single most useful attachment, for me, on my tractor!!
(The backhoe is number two. For tools my chainsaws are third on the list, followed by the wood splitter.)
/ Finished loader for old MTD tractor #7
Yep, great job.
Some rear-ballast hanging off the back may help stability and that steering issue.
Thanks for thr pics, good job.
My tires weight 50# each plus 50# of wheel weight. If I need more ballast I plan on building this weighted platform. It is made from 6"sq. tubing filled with sand and adding 1/2" plates as needed. It will be attached on my 3ph. I have all the material all I need to do is weld it together.
/ Finished loader for old MTD tractor #9
Thanks for sharing. Great job.
/ Finished loader for old MTD tractor #10
I have an 1,100 lb hoe on rear, some times it feels like I could use more- that weight box sounds pretty good to me..:)
/ Finished loader for old MTD tractor #11
See if you can get punch press rounds for scrap price... that makes it about 4 times heavier than a sand fill.
/ Finished loader for old MTD tractor #12
Is it still working ok? Any problems?
David from jax
sandman2234 ~~ I did have a problem with the tie rod bracket it broke off when I was hauling stone. I found out that the bracket was broken before because half of the crack was rusted. I welded it back together and it works fine. I do have a leak from one of the used lift cylinders. I thought that the seal was "OK" but under full pressure it is not. It is the front seal on the right hand cylinder. I do have more cylinders so I will rebuild one to replace it this winter. I'm having too much fun using it to stop and rebuild it at this time.
/ Finished loader for old MTD tractor #14
Blacksmith,
Where did you get the steel hydraulic lines made?
hogi ~~ The tubing I used was scrap pieces from work. It is made with nickel so it will not rust and it is stronger than regular steel tubing. I bent the angles myself and either welded or used "Swagelok" fittings or made my own. I used 3/8 tubing because it was free. I bought my hoses and some fittings from surpluscenter.com or northerntool.com.
/ Finished loader for old MTD tractor #17
could u get some sizes of ur loader and mounnts, what type of pump did u use and what did u use for a reservoir. why asking so much is cause i got a tractor identical to urs only it is labeled farm king. but is a 990
211453 (A62131)
211453 (A62131)
24in. Bucket w/ Teeth Excavator Attachment (A64194)
24in. Bucket w/...
Yale Forklift - NO RESERVE! (A63689)
Yale Forklift - NO...
2005 Stertil Koni ST-1082R 18000lbs 4-Post Auto Lift (A61572)
2005 Stertil Koni...
Truck Tool Box (A65640)
Truck Tool Box...
275 Gallon Cage Tanks, Koser Safe, with 2" outlet (A62679)
275 Gallon Cage...
