Finished loader for old MTD tractor
   / Finished loader for old MTD tractor #11
See if you can get punch press rounds for scrap price... that makes it about 4 times heavier than a sand fill.
   / Finished loader for old MTD tractor #12
Is it still working ok? Any problems?
David from jax
sandman2234 ~~ I did have a problem with the tie rod bracket it broke off when I was hauling stone. I found out that the bracket was broken before because half of the crack was rusted. I welded it back together and it works fine. I do have a leak from one of the used lift cylinders. I thought that the seal was "OK" but under full pressure it is not. It is the front seal on the right hand cylinder. I do have more cylinders so I will rebuild one to replace it this winter. I'm having too much fun using it to stop and rebuild it at this time.
   / Finished loader for old MTD tractor #14
Blacksmith,
Where did you get the steel hydraulic lines made?
hogi ~~ The tubing I used was scrap pieces from work. It is made with nickel so it will not rust and it is stronger than regular steel tubing. I bent the angles myself and either welded or used "Swagelok" fittings or made my own. I used 3/8 tubing because it was free. I bought my hoses and some fittings from surpluscenter.com or northerntool.com.
   / Finished loader for old MTD tractor #17
could u get some sizes of ur loader and mounnts, what type of pump did u use and what did u use for a reservoir. why asking so much is cause i got a tractor identical to urs only it is labeled farm king. but is a 990
2014 MACK GU713 WATER TRUCK (A51243)
2014 MACK GU713...
MAGNUM PRODUCTS. 35KW GENERATOR (A50854)
MAGNUM PRODUCTS...
Stump Grab Bucket (A50322)
Stump Grab Bucket...
2018 HINO 258 SERVICE TRUCK (A51243)
2018 HINO 258...
2016 Ford Escape 4x4 SUV (A50324)
2016 Ford Escape...
2005 International 4300 Heil Dump Truck (A50323)
2005 International...
