Rear Finish Mower Finish Mower Size
/ Finish Mower Size #1
467ron
Troy,MI
Ford,8n
I have a 1949 8N should that be able to handle a 5 foot finish mower?
/ Finish Mower Size #2
I used a five foot finish mower on a John Deere M, about the same horsepower. It would bog down if I was in very heavy grass, but under normal conditions it handled it well. Don't forget to use an overrunning clutch to prevent the mower from driving the tractor when you push the clutch in.
Pat
/ Finish Mower Size #3
+1 on the overrunning PTO clutch. If you do not know what it is here is a write-up from tractordata.com. You can purchase them from TSC. I got a friend to purchase one and now is NO longer running into things when he is using his rotary cutter on his Ferguson.
TractorData.com - Overrunning PTO Clutch
6 1/4 INCH OD 90 DEGREE ELBOWS (A67714)
6 1/4 INCH OD 90...
2019 VOLVO A45G OFF ROAD DUMP TRUCK (A65053)
2019 VOLVO A45G...
1987 Polar 307 SS 3 Comp SS Insulated T/A Chemical Tanker Trailer (A68183)
1987 Polar 307 SS...
2015 CHEVROLET IMPALA (A66091)
2015 CHEVROLET...
2006 CASE 430 SKID STEER (A65056)
2006 CASE 430 SKID...
Unused 2023 Monroe Tufline TW693222 12ft. Pull Behind Disc Harrow Tractor Attachment (A66734)
Unused 2023 Monroe...
