Finish mower chains
/ Finish mower chains #31
Maybe a dumb question you guys and maybe its been asked sorry but do those chains ever hit the blades?
I see they would be **** on rocks and sticks keeping them under the deck thats a great idea!
/ Finish mower chains #32
Thats why you make them short enough and that they stick out far enough so that there is no way they can hit the blades.
/ Finish mower chains #33
After I had them mounted on the mower deck, I went around chain by chain and made certain they could not reach the tip of the blades. I had to trim a few, which made me glad I double checked. :D
/ Finish mower chains #34
Well thats what I would have guessed but on my rough cut the blades come pretty close to the end of the deck so I was just curious thanks!
I wouldn't mind having something like those chains on mine to slow down the projectiles good job guys I may use that idea someday!
/ Finish mower chains #35
What you need to do is get like a 4" wide (or whatever it needs to be to work) piece of 1/4 metal or some flat stock and weld it to the top of the deck, then drill it out and hang your chains off of it, that way you space them farenough from the blades but still can be long enough to stop the peices that would be air born.
/ Finish mower chains #36
Can do thanks clemson!
/ Finish mower chains #37
So, after all of that work, I decided to take off the chain guard I made for my rotary mower. Here's why:
1) Although I checked each chain to make sure it couldn't reach the blade... it turned out that several of them could and did. As you can imagine, it was hard on the tip of the blades. I think the issue was that the blades droop when it's stationary (like when I was measuring) and lift up when it's running. That extra lift was enough... whack!:thumbdown:
2) When things ejected from the mower (and/or when the blades hit the chains) it was throwing the chain around and hitting the deck so hard that it was knocking the paint off. Yes, my nice new paint job...:shocked:
3) After taking off the chains, I ran the mower some more. I could tell that the chains were making the tractor work harder because of keeping things underneath the deck longer. It was a big enough difference that I was able to run the mower in the next higher gear with the chains off. :thumbsup:
4) Even with the chain guard, I didn't want my son out watching me mow the field. Given that no one will be anywhere near, the chains are not a necessity and I don't feel too bad about mowing my field without them. I do feel a little bad about all of the work I put into them. :D
Tandem Axle Rear Truck Frame (A59230)
Tandem Axle Rear...
2011 Armstrong Marine Pilot House Boat with Tri Axle Magic Tilt Tri-Axle Boat Trailer (A59231)
2011 Armstrong...
2019 Ford F150 XL (A57148)
2019 Ford F150 XL...
(INOP) 2011 FORD F-150 XL SINGLE CAB TRUCK (A59823)
(INOP) 2011 FORD...
2012 Chevrolet Traverse LT SUV (A59231)
2012 Chevrolet...
2021 KENWORTH T680 TANDEM AXLE SLEEPER (A59575)
2021 KENWORTH T680...
