Fine thread bolts - what advantage?
/ Fine thread bolts - what advantage? #1
Ford850
Super Member
Ohio
Case DX55, Ford 850
What advantage do fine thread bolts have over coarse threads? I notice on most old implements, the bolts are fine thread rather than coarse. I'm working on an old plow now and have to replace quite a few bolts as I go. They are various sizes ranging from 3/8 up to 3/4. I can buy coarse thread grade 5 or 8 at TSC, which is handy. But if I want to use fine thread I have to make a 30 mile trip to a dealer each time I need a few.
/ Fine thread bolts - what advantage? #2
A fine thread bolt has more clamping power for lack of a better term. If you put a 6" wrench on a fine thread bolt and a corse thread and pull with the same force the fine thread will be tighter because of the pitch of the threads. Also fine thread wont vibrate loose as easy.
Bill
/ Fine thread bolts - what advantage? #3
A fine threaded nut/bolt will be stronger under tension. In addition, a fine thread will allow you to apply more pressure to the joint in tension since the fine thread requires more turns when mating your joint (acts like a lower gear). If your joint is a shear joint, the fine may be less important but you still won't get the joint pinched as tight using course threads. If threading into aluminum or something soft, a course thread is stronger.
Hooked is a faster typer.
/ Fine thread bolts - what advantage? #4
This is an important point added to what Hooked said. [color added] There is a greater stud diameter in the root of a fine thread as compared to equal sized coarse. The fine bolt is stronger. Fine threads require more care in assembly and disassembly however to avoid damage by physical abuse or included dirt.
larry
/ Fine thread bolts - what advantage? #5
i'll also add that fine threaded bolts can be much more difficult to remove when rusted/dirty due to the threads being more easily contaminated. i usually end up twisting or cutting them off if they have much rust.
modern machining techniques allow for more precision in fasteners. i prefer a corse threaded grade 8 bolt with lock washer for most ground engaging equipment. use a little anti-seize compound when putting it together and you'll have no problem doing maintenance and the lock washers or star washers should keep them from vibrating loose.
if you have a really bad problem with vibration (aside from fixing the source of it if possible) you can double nut any bolts that keep vibrating loose even with lock washers.
amp
/ Fine thread bolts - what advantage? #7
Fine threaded bolts have one advanage and one only, you can torque them tighter and to a higher preload plain and simple.
Torque is torque, no matter if its course threads or fine threads, and the bolt preload is all the same. Why can a fastener with fine threads take more more torque? Because there's more threads spreading the load out over more thread area. When your torque increases your bolt preload and tension increases and thus the friction between the (2) pieces being bolted increases. Remember, other then when a bolt is used in a shear application, you are relying on the friction of the mating surfaces to keep everything together, the bolt is there just to create the friction and clamping force.
Craig
/ Fine thread bolts - what advantage? #8
Craig
It is like going uphill with your tractor pulling certain load at certain speed and maximum power. If the slope is half you will be able to pull twice the load.
The load is the equivalent of bolt preload.
/ Fine thread bolts - what advantage? #9
In the machine shop, as a rule, we always used coarse threads for bolts going into castings and fine threads when using nuts...
/ Fine thread bolts - what advantage? #10
Fine Thread with a nut when very high clamping action is needed and you do not want it to vibrate or work loose. For example the cutting edges, corner bits and track pads of a D8 CAT. Never seize and a torque multiplier for the pad bolts.
Mike
/ Fine thread bolts - what advantage? #11
Torque is torque, no matter if its course threads or fine threads, and the bolt preload is all the same. [[[Why can a fastener with fine threads take more more torque? Because there's more threads spreading the load out over more thread area.]]] When your torque increases your bolt preload and tension increases and thus the friction between the (2) pieces being bolted increases. Remember, other then when a bolt is used in a shear application, you are relying on the friction of the mating surfaces to keep everything together, the bolt is there just to create the friction and clamping force.
Craig
NO! This is not the reason for the fine "v form" thread bolt being able to take more torque. It can take more torque because the diameter of the bolt is greater at the root of the thread than a coarse one. This means theres more material to withstand the combined tensile and torque load.... - The coarse thread has to be cut deeper into the bolt to form the v with coarse thread. Also, as stated by Hooked, torque for torque the clamping force is higher with a fine threaded bolt. This is due to the more gradual angle formed by the fine thread helix. Post 3, jejeosborne, said this well.
larry
/ Fine thread bolts - what advantage? #12
I just finished cutting the heads off the 5/8"x3.5" fine thread bolts that held the outer rims of the rear wheels onto the 1951 Minneapolis Moline BF tractor that I'm restoring. No way those rusted old things were coming apart normally.
I'll replace these with $1.50 5/8" coarse thread bolts and split ring lock washers. Won't lose any sleep over any differences in torque levels betwen the two types of threads since the BF will be a parade tractor.
/ Fine thread bolts - what advantage? #13
Lotsa guys with 6 loop rims have went to coarse thread stuff with no los of sleep..
soundguy
/ Fine thread bolts - what advantage? #14
Save yourself a few cents and skip the lock washers. There is more rim-to-disc hardware out there without LW's than with. Hardware installed and torqued properly doesn't need lock washers. Ever see a cylinder head bolt or main bearing cap bolt with one?
/ Fine thread bolts - what advantage? #15
A little Trivia...
Until the automotive era entered the arena, all threads were USS.
Automotive requiring more torque introduced the SAE thread.
What do these two acronyms stand for??:confused:
United States Standard=USS:cool:
Society of Automotive Engineers=SAE:cool:
/ Fine thread bolts - what advantage? #16
Everything you need to know is in here :
Information related to bolted joints
Take the tutorial on bolted joints. Also, watch the Junkers machine videos. One validates what a few of the posters said about don't bother w the lockwashers!
The diff bet fine/coarse threads is in the FAQs. Also in the FAQs, look at the discussion of locknuts (double nutting).
/ Fine thread bolts - what advantage? #17
A little Trivia...
More clamping power with the same torque or the same clamping power with less torque.
2023 WALLACE-THE ROOSTER ROOT PICKER PINTLE HITCH (A65054)
2023 WALLACE-THE...
2012 TYTAL (A67714)
2012 TYTAL (A67714)
PALLET OF 2CYL GAS ENGINE/RADIATORS AN PARTS (A68842)
PALLET OF 2CYL GAS...
HEAVYEQUIPMENT PRESSURE WASHING PARTS (A68842)
HEAVYEQUIPMENT...
2017 Autocar Xpeditor T/A New Way 31ASL 31yd Side Loader Garbage Truck (A66736)
2017 Autocar...
2014 MAC FLAMELESS HEATER TRAILER (A67714)
2014 MAC FLAMELESS...
