Finding drain tile
   / Finding drain tile #1
Hooked_on_HP
Coal City IL
Ford 1900 FWD Kubota F2100E
I know my property has drain tile, but I am not shure exactly where they are. I think a couple of them might be pluged with roots or sand. Does anyone have an easy way to find them without digging a lot of unnecessary holes,which I have already done.
Bill
   / Finding drain tile #2
Video snake. Not only can you see where or if theres blockage, you can use a detector from the surface to find where the tile is and its route, then mark exactly where to dig.
Call your local rentals or look for a contractor. Will save much money and work from digging un-necessary holes.
   / Finding drain tile #4
If you have an idea of where they are, you can get a fiberglass "T" probe from plumbing supply house, or make one yourself.
It is about 4' long with a 1' handle that makes the T. It is a simple probe, since most drain tile is burried in gravel you can usually find by probing in the area.
   / Finding drain tile #5
Try a coat hanger before you spend much money, this really works for me. Try it where you know a pipe is buried to check it out.
WikiAnswers - Is there a tool or device that can detect or find under ground water lines that do not have a magnetic strip
Dowsing
dowsing (a.k.a. water witching) - The Skeptic's Dictionary - Skepdic.com
Web Exclusive! Water Witching How-To - Feature Articles - Point of Beginning
Ranks right up there with predicting the stock market.
Some people can, some can't.
Don't dig based on it.
2011 26PS PROWLER 5TH WHEEL RV (A52472)
2011 26PS PROWLER...
2012 NEW HOLLAND BOOMER 3045 COMPACT TRACTOR WITH 250TL LOADER (TRANSMISSION ISSUES) (A55301)
2012 NEW HOLLAND...
Estate Equipment Auction 9/27/2025
Estate Equipment...
2019 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A52377)
2019 HarbinGer V3...
