Traction Finally yanked my boat out with a B2320
   / Finally yanked my boat out with a B2320 #1
mswlogo
NH, USA
Kubota B2320 DT (Gear)
I've been trying for years to get my boat out with something less than my Jeep.
I decided to give it one more go. Before using my new Jeep which I really didn't want to cover in sand just yet.
Loaded up front end loader with wet sand.
Weaved ropes on front tires as a wimpy chain (I don't think this helped)
Left boat hanging off the back of trailer so it would float longer (I don't think this helped, maybe made it worse.)
My first attempt, I had Transfer Case in Low and Transmission in 1st gear (lowest gear).
It was going real smooth and then it just stopped and dug in.
The Jeep "Paddles" through the sand.
I didn't think the little 23HP Kubota had enough torque in a much higher gear and never tried it.
So I put the Transfer case in Medium and Transmission in 2nd. It got further. I was ready to quit, when I realized I had the break on, Grrrrr.
Tried it again with break off :) and it cruised right out. 4500 LBS in very soft sand, on Turf tires (and tires did load up instantly).
I wanted to also lock the left/right rear Diff. So I used the hand throttle at WOT. So I kept my right foot on the Diff Lock and let out the clutch.
Momentum was the trick and paddling through to keep the momentum going.
Since the sand "let go" the tractor still had the Torque (to paddle) at this higher gear. If it had full traction, with that weight, in that high gear it would have stalled.
   / Finally yanked my boat out with a B2320 #2
Always nice to find a new use that keeps the clean toys clean and the dirty toys playing in the dirt. :D
   / Finally yanked my boat out with a B2320 #3
Your commentator didn't seem so confident!
Congrats!
ac
Congrats!
ac
I really meant years. And this was right after my leaving the break on.
I have the video of leaving the break on and my discovery of that minor lapse of memory. It is so **** funny. Lots of 4 letter words.
   / Finally yanked my boat out with a B2320 #5
Good Job. Nice boat and tractor
   / Finally yanked my boat out with a B2320 #6
Are you kidding me, your Kubota laughed before it yanked that boat out of the water. Good job and it looked like it only slowed down for a second.
   / Finally yanked my boat out with a B2320 #7
Agree, I didn't see any real struggle, nor would I have thought there'd be much. Compare pulling that boat out to pulling a box blade full of dirt with the scarifiers down. I would expect that latter to be a tougher job. All the same, glad it worked out for you, mswlogo, and you kept your Jeep "high and dry".
   / Finally yanked my boat out with a B2320 #8
Perhaps you and Dodgeman are not familiar with the dynamics of retrieving boats on a beach (or sand driving in general). Its not about power. Its all about momentum. The tractor has ample power, as Mswlogo knows, but it often cannot accelerate quickly enough to power through the soft sand before the wheels lose traction and start spinning. You need to rapidly get up to a speed where the weight of the boat is helping to 'push' the boat through the soft sand rather than dragging it backwards. I pull out my boat with a little 1.3 litre Suzuki Sierra (a Samurai to you). It has no power but it has the required acceleration and traction.
The critical time starts around the 8 second mark. The tractor is already at top speed in its chosen gear. Its around here that Mswlogo's stomach starts to knot up as he feels the wheels start to bog down and spin.
(edit. My comments above apply to 4wd cars and small tractors. Big tractors with big aggressive ag tyres can often just 'dig' their way to the top of the beach.)
   / Finally yanked my boat out with a B2320 #9
Nice. I pull my boat ~6k lb boat around with my b2920 in M a lot, it's amazing how much pulling power these little tractors have! Impressive you were able to do it in the sand!
2006 MACK MR CAB & CHASSIS (A57880)
2006 MACK MR CAB &...
2001 Dodge Ram 1500 Pickup Truck (A55852)
2001 Dodge Ram...
UNUSED FUTURE 350 HYD BREAKER HAMMER (A52706)
UNUSED FUTURE 350...
2015 International DuraStar 4300 26ft. Box Truck (A55852)
2015 International...
2018 Ford Explorer AWD SUV (A55853)
2018 Ford Explorer...
2015 Ford Taurus AWD Sedan (A54815)
2015 Ford Taurus...
