Finally, I've turfs : )
/ Finally, I've turfs : ) #1
project_X
Ottawa, ON, Canada
Kubota L235DT and L225
Finally, I\'ve turfs : )
I have a Yanmar 1602D that had AGs, and I wanted to get turfs on it.
Last year I purchased a set of these tires on ebay for the rear. I finally got the adpater plate to convert the bolt patterns from JD to Yanmar. I mounted them last night and re-checked the RCI to verify the required fronts. I found that JD has the fronts for a 4110 (LVA11662)available which will bolt directly on and accept 23-8.5x12 turfs and preserve the require ratio front to rear. I ordered the fronts and will get them on this weekend.
Hope this helps others.
Cheers,
Rob
Cheers,
Rob
/ Finally, I've turfs : ) #3
Re: Finally, I\'ve turfs : )
What a bargain and you'll love them. The handling characteristics will be completely different.
Eugene
/ Finally, I've turfs : ) #4
Eugene
2006 Ford F-350 Crew Cab MOT Safety Truck (A66736)
2006 Ford F-350...
2011 Terra Riser 300D-SA Fire Plow Attachment (A61572)
2011 Terra Riser...
2007 MACK VISION (A67714)
2007 MACK VISION...
2013 40' Hi-Cube Container (A64912)
2013 40' Hi-Cube...
2007 Ari-Hetra HDML-8 60,000lb Four Post Auto Lift (A66736)
2007 Ari-Hetra...
Rears 3pt 1000 Gal Orchard Sprayer (A64911)
Rears 3pt 1000 Gal...
