Tiller finally got use my 7' kk tiller
   / finally got use my 7' kk tiller #11
Here ya go. Doubled the pic size and halved the file size for ya.
thanks haywire that looks dang good
   / finally got use my 7' kk tiller #13
Thanks for posting your tiller purchase Lucky. I have been looking at that same tiller. It sure looks like it does a good job. What HP tractor are you running it with?
i have a 55 horse 4x4 it says it has 45 at the pto which is more than enough to turn that tiller it never bogged down one of the guys gardens i tilled was really hard packed clay it took a couple passes to bust it up right another thing that was a problem in that patch was there were small terraces that the shoes were riding on and the center of the tiller couldnt reach the dirt so i had to slow my speed and eat away at the terrace so the tiller would drop into the dip worked out pretty good i was running it in 1 low at 540 and it never skipped a beat even when i snatched up a 8 foot ground rod lol oh yeah it says it takes 100 ounces of 85 w 140 oil for the gear boxes so i bought 4 quarts so i would have some left over make sure you buy 6 quarts i had to make 2 30 minute trips to the store
   / finally got use my 7' kk tiller #16
It looks like that tiller does a great job. i have been thinking about buying either a 5 or 6 footer for my 30 horse kubota, and using it to till my horse arena and redo my yard. my question is, how well do these tiller work in breaking up the existing sod if i redo my yard, and if i make multiple passes and drag it with a chain harrow, will it be good enough to reseed.
Spray the yard with round-up first and let the grass die, then till it up. Will work up very nice.
   / finally got use my 7' kk tiller #17
Yes, they are the perfect tool for that. As mentioned above, just spray roundup first to kill the existing vegetation and its roots, then till. Make sure you read the directions on the Roundup.
If you don't kill the existing veg. first, it will make cleanup take a lot longer and a lot of it will re-grow again.
I just did one of those jobs for a customer. Here's the York Rake phase. Prior to that, I used a Harley rake to break up soil and get the rocks out.
MISC TIRES (A54757)
MISC TIRES (A54757)
UNUSED IRANCH 1RTPL 10,000# TOW POST LIFT (BLUE) (A57193)
UNUSED IRANCH...
Bear Statue (A55853)
White Metal Roof Panels (A55758)
White Metal Roof...
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
2002 Bobcat 763 Compact Skid Steer (A57024)
2002 Bobcat 763...
