Finally found a good gas can
   / Finally found a good gas can #21
if i got caught spending $21 on a fuel can i'd be sleeping with the tractors and the atv's in the barn. but that does look like it would work better than what i've got now.
I hear you, I had to think about it awhile before I coughed up the money too:laughing: Paying over $20 for a gas can does leave you feeling violated.:eek:
   / Finally found a good gas can #23
I may just go back to storing gas in the old plastic milk jugs. It would be better than new cans out now.
IFew years ago I bought a new metal 'jerry can' at Northern Tool and it had the good nozzle which pushes back and lets fuel flow until you release pressure on the can/pull it out of the tank.
Really messed up when I didn't buy a handful of the replacements they had there for sale at the time. :mad::(:mad::(
   / Finally found a good gas can #24
I have 4 of the no spill containers. One is yellow for diesel. I wish they had blue for kerosene, they work great for filling my kerosene heater in the shop. -Keith
   / Finally found a good gas can #27
Like everyone else, I grew weary of using the newly designed fuel cans.... climbing up on the tractor and balancing five gallons of diesel is no job for a one-legged fat man... at first, I drilled and tapped threads in my cans and installed a thumb-screw in the hole... remove the thumb screw and vent the can... works much better.
Recently I'v begun buying off-road diesel ( much less expensive) and putting it in a 55 gallon barrel.. equipped this with a 12-volt pump and can fill my fuel tank in less than 2 minutes.... I never knew life could be so good. lol
   / Finally found a good gas can #28
Recently I'v begun buying off-road diesel ( much less expensive) and putting it in a 55 gallon barrel.. equipped this with a 12-volt pump and can fill my fuel tank in less than 2 minutes.... *I never knew life could be so good. lol
I heard that::thumbsup:
Folks that don't have it don't know what they are missing till then get it?;)
   / Finally found a good gas can #29
A few years ago I bought a new metal 'jerry can' at Northern Tool and it had the good nozzle which pushes back and lets fuel flow until you release pressure on the can/pull it out of the tank.
These don't work well when trying to pour into a funnel .
   / Finally found a good gas can #30
... Recently I'v begun buying off-road diesel ( much less expensive) and putting it in a 55 gallon barrel.. equipped this with a 12-volt pump and can fill my fuel tank in less than 2 minutes...
I wanna do this too!
Where can I get a 55 gallon barrel?
Are you using an car/ truck fuel pump?
Do you take the barrel to the station to fill it?
I guess you could keep the barrel on a pallet & fork lift it on & off the bed of a truck?
2013 Freightliner M2 106 Elgin Broom Bear Series H Street Sweeper Truck (A55788)
2013 Freightliner...
2022 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A56858)
2022 Chevrolet...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A55315)
2023 Unverferth...
MISC TIRES (A54757)
MISC TIRES (A54757)
Caterpillar 906M (A53317)
Caterpillar 906M...
2017 Ford F-350 Flatbed Truck (A56858)
2017 Ford F-350...
