Finally found a good gas can
   / Finally found a good gas can #21
if i got caught spending $21 on a fuel can i'd be sleeping with the tractors and the atv's in the barn. but that does look like it would work better than what i've got now.
I hear you, I had to think about it awhile before I coughed up the money too:laughing: Paying over $20 for a gas can does leave you feeling violated.:eek:
   / Finally found a good gas can #23
I may just go back to storing gas in the old plastic milk jugs. It would be better than new cans out now.
IFew years ago I bought a new metal 'jerry can' at Northern Tool and it had the good nozzle which pushes back and lets fuel flow until you release pressure on the can/pull it out of the tank.
Really messed up when I didn't buy a handful of the replacements they had there for sale at the time. :mad::(:mad::(
   / Finally found a good gas can #24
I have 4 of the no spill containers. One is yellow for diesel. I wish they had blue for kerosene, they work great for filling my kerosene heater in the shop. -Keith
   / Finally found a good gas can #27
Like everyone else, I grew weary of using the newly designed fuel cans.... climbing up on the tractor and balancing five gallons of diesel is no job for a one-legged fat man... at first, I drilled and tapped threads in my cans and installed a thumb-screw in the hole... remove the thumb screw and vent the can... works much better.
Recently I'v begun buying off-road diesel ( much less expensive) and putting it in a 55 gallon barrel.. equipped this with a 12-volt pump and can fill my fuel tank in less than 2 minutes.... I never knew life could be so good. lol
   / Finally found a good gas can #28
Recently I'v begun buying off-road diesel ( much less expensive) and putting it in a 55 gallon barrel.. equipped this with a 12-volt pump and can fill my fuel tank in less than 2 minutes.... *I never knew life could be so good. lol
I heard that::thumbsup:
Folks that don't have it don't know what they are missing till then get it?;)
   / Finally found a good gas can #29
A few years ago I bought a new metal 'jerry can' at Northern Tool and it had the good nozzle which pushes back and lets fuel flow until you release pressure on the can/pull it out of the tank.
These don't work well when trying to pour into a funnel .
   / Finally found a good gas can #30
... Recently I'v begun buying off-road diesel ( much less expensive) and putting it in a 55 gallon barrel.. equipped this with a 12-volt pump and can fill my fuel tank in less than 2 minutes...
I wanna do this too!
Where can I get a 55 gallon barrel?
Are you using an car/ truck fuel pump?
Do you take the barrel to the station to fill it?
I guess you could keep the barrel on a pallet & fork lift it on & off the bed of a truck?
2019 GENIE S-45XC TELESCOPIC BOOM LIFT (A52709)
2019 GENIE S-45XC...
Gas Pump Artwork (A55758)
Gas Pump Artwork...
2023 Kubota Z412KW-48 Commercial Zero Turn Mower (A55315)
2023 Kubota...
2002 Chevrolet C8500 Flatbed - CAT 3126 Diesel - Eaton Fuller 8 plus 2 Transmission (A56435)
2002 Chevrolet...
2005 Volvo VNL Truck, VIN # 4V4N19TGX5N374968 (A57453)
2005 Volvo VNL...
2021 Unverferth 432 Rigid 4 Row 36-inch 3PT Ripper Bedder (A55315)
2021 Unverferth...
