Finally finished my brush forks
/ Finally finished my brush forks #1
HokieMS
Buchanan Va
JD 4005
It took me while waiting on nice days and time off to work outside, but they are done. I used them for about an hour, and so far, so good. Let's see if I can manage to post some pictures.
Answer: No. My tablet is a pain. Maybe later I will edit on my computer to add the pics, but for now the links will have to do. Hopefully they work.
https://db.tt/Rvad7fU1
https://db.tt/wuDAowL5
https://db.tt/GZTpPVzS
https://db.tt/1v7jdSMy
https://db.tt/xQsrAuGj
https://db.tt/JIOtNqCZ
The piles of brush have been on the ground for a while and were rotten on the bottom. Fresh piles will pick up more completely with less material falling through the tines. Overall I am pleased considering I am a complete amateur at fabrication.
/ Finally finished my brush forks #3
The links work. I like the design, first that I have seen with shorter tines on the outside, should work better on uneven ground.
I like the receivers on the bucket, so you can run the chain or strap either way. The back gives the most lifting power.
:thumbsup:
/ Finally finished my brush forks #5
Beautiful work. What size tubing did you use?
Thanks everyone. The tube is overkill, if I was starting over I'd go smaller. It is 1.5", 1/4" wall.
Xfaxman, my main motivation for the shorter tines was tighter turning in close quarters.
/ Finally finished my brush forks #7
I like your design... more or less what I plan to make myself. I have some 1.5" pipe and plan on 6 tines @ 12" spacing.
Nice work.
/ Finally finished my brush forks #8
Hi Hokie,
Awesome build!
In your second to last picture, it looks like the end tines run along the lower outer edge of the bucket, but in the last picture it looks like it has been shifted under the bucket, can you help me understand?
Also, is there any chance you can post pictures under the bucket to show how you attached the ratchet strap to the forks?
Does the upper/back end of the strap just hook onto the upper bucket edge?
Thanks,
Thomas
Thomas,
Thanks for the compliment.
It's really hard to tell ftom the pictures but the forks are in the same position in both shots. The outer tines are basically just inside the side plate of the bucket.
As far as the straps, the top hooks are hooked on the end of the pin that holds my 2" receiver drawbar hooks in place. The bottom hook attaches to 5/16" eye bolts that are installed in the angle iron cross piece on the back of the forks. I just drilled a hole a few inches from both corners and tightened down the eye bolts with a jam nut. I took a picture to show that, but it had too much glare from the sun.
Let me know if that answers your questions.
Mark
/ Finally finished my brush forks #10
Great build and looks like it will do the job and last a long time. I also like the receiver on the top, great idea.
/ Finally finished my brush forks #11
Thomas,
Mark
Hi Mark,
No compliment intended, just an objective observation.
You explained it perfectly, and I see what you did there.
Thanks!
Thomas
/ Finally finished my brush forks #13
good idea, I love the simpicity of that tool. What is the lenght of the longer tube ? How is the spring on tube when you work with?
good job I love this, and continu to be artisanal amateur, I one of those to!
yoann,
The longer tooth is about 4 feet long, with about 1 foot running under the bucket. So with 3 feet sticking out past the bucket, I have plenty of capacity to lift brush.
I think "spring" means how much bend occurs when lifting? I can hang my weight from the middle tine, and it will bend downwards maybe an inch. The C-channel used for the middle bracing really stiffened it up. I was worried it would flex too much, but I'm glad I didn't use more tubing for the brace, it is already heavy enough as it is.
Let me know if this is clear for you.
Mark
2018 KENWORTH T680 TANDEM AXLE SLEEPER (A59904)
2018 KENWORTH T680...
CHALLENGER MT525B TRACTOR (A59823)
CHALLENGER MT525B...
case 370 glass door never installed (A61306)
case 370 glass...
7074CFL (A59228)
7074CFL (A59228)
2002 Bobcat 863 High Flow Compact Wheel Loader Skid Steer (A59228)
2002 Bobcat 863...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
