Finally finished Disk Harrow
/ Finally finished Disk Harrow
View from the tractor seat, I have used it and it works just beautifully (sp) /forums/images/graemlins/grin.gif
My little helper, QC inspector and tractor companion.
I started on the frame it in Febuary and had it done in a few weeks (I'm slow), my plasma cutting took a month of waiting on a individual that was in no hurry to do a 15 minute job.
I don't know the cost...I don't want to know, I had fun building it.
I did take the time to cap most of the tube ends for a cleaner look and my paint job is not the greatest (I am not a Painter)
I know some of y'all may be thinking why blue and not Kub orange....well I like blue and it is custom/home built /forums/images/graemlins/grin.gif
The frame is like a KingKutter and is suppose to be a 5 1/2'
model and this winter I plan on buying the extra parts to make it a 5 1/2' model.
I used a MM175 for all the welding. I know I need something bigger, I have a MM251 on my wish list.
So far I am pleased with it, it does what it is suppose to do and my L2800 pulls it with no problem even in 2wd.
My list of building material is something like this.
3/16X2"X3" tubing for the basic frame.
1/2"X3" flats for the cross over on the tubes.
1/2"X3" flats for the captured pins.
1/8"X1"x2" for the stiffiner for the top link.
3/8"X6" angle for the gangs.
3/8"X6 flats for the gangs.
The rest of the gang parts came from Agri-supply except for the 1/2" "U" bolts and 1/2" bearing bolts.
Paint is Rustoleum International Blue.
/ Finally finished Disk Harrow #47
Very nice work and I have to learn more about a disc harrow and what they do, I might need one of these?
Jim /forums/images/graemlins/smile.gif
/ Finally finished Disk Harrow #48
/ Finally finished Disk Harrow #49
washaw, glad to see you finished your disk. Great looking job, and the star is a nice touch for a custom look. And who cares if it's blue, it's your disk and if thats the color you like go for it. Again, nice job
/ Finally finished Disk Harrow #50
/ Finally finished Disk Harrow #51
wushaw,
Nice job on the disk. I especially like the star on top. /forums/images/graemlins/grin.gif
/ Finally finished Disk Harrow #52
wushaw,
/ Finally finished Disk Harrow #53
I think the star should be white ......red? .....guess I'm old enough to remember the cold war....
/ Finally finished Disk Harrow #54
/ Finally finished Disk Harrow #55
VERY nice work! Mine is a fairly light one made of angle iron & only adjusts the cutting angle with bolts. Yours is much heavier & the easy angle adjustment is pretty slick.
/ Finally finished Disk Harrow #56
/ Finally finished Disk Harrow #57
wushaw,
Excellent project!
I recently replaced 1 axle, 5 cutters, and 5 or 6 spools, and it nearly cost me as much as I paid for the disk harrow brand new. Although your disk is way better than a comparable bought one, it must have cost quite a bit more, right? Yours looks to have bearings instead of the spools, right?
A few observations from someone that's had a lot of trouble with disk harrows:
Grease, grease, grease. (assuming spools)
Butt welds on lower arm brackets will eventually give way.
The big axle nuts will try their best to loosen and destroy your axles.
Flat plate steel brackets holding the axles will flex back and forth. Gussets could make them stiff and quiet them down.
A good dog is worth more than a good tractor.
/ Finally finished Disk Harrow #58
wushaw,
Excellent project!
/ Finally finished Disk Harrow #59
Outstanding job on the disc!!
Nice tractor, nice dog.
What I'm really envious about is your beer can cover !!!
Cheers!
/ Finally finished Disk Harrow #60
Cheers!
KBH 25 TON TENDER (A61307)
KBH 25 TON TENDER...
2011 Freightliner M2 106 Chip/Dump Truck, VIN # 1FVACWDU7BDAU8870 (A65563)
2011 Freightliner...
2022 EZ-GO ELITE...
12' x 24' Cattle Shelter (A66408)
12' x 24' Cattle...
New/Unused Spirit Electric Tricycle (A65583)
New/Unused Spirit...
2016 Isuzu NRR Trash Truck, VIN # JALE5W162G7300782 (A65563)
2016 Isuzu NRR...
