filters for ford 1210
/ filters for ford 1210 #1
chefirv
north providence, RI
ford 1210
i am looking to replace air,fuel, hydraulic filter for 86 ford 1210
i don't have a tractor supply store in my state.
any sugeestion or a good source of where to buy some parts??
first time owning a diesal
thanks
/ filters for ford 1210 #3
NAPA carries them here, but any major auto and truck parts store should be able to get them.
David from jax
/ filters for ford 1210 #4
any suggestion or a good source of where to buy some parts??
thanks
For my Ford 1700 I was able to cross reference it with Fram website. It works well. I suggest you check it out.
JC,
/ filters for ford 1210 #5
fram and napa both have an application crossover chart.. should be able to go anywhere once you have those numbers.
soundguy
/ filters for ford 1210 #6
Wix Filters
Search Results Part Part No. Filter
Air Filter 46270 1210 w/S723 Diesel Engine
Fuel Filter 33264 1210 w/S723 Diesel Engine
Oil Filter 51396 1210 w/S723 Diesel Engine
: Where to Buy
Andy
thanks guys for all the info
i bought them and plan on doing it this weekend
/ filters for ford 1210 #8
Somebody with a ford 1210. I just got one with backhoe and FEL. Seems in good shape generally but any thing specific to watch out for. It seems to work fine for what I need it for. Thanks
if you are looking for oil filter fram has one ph2951 that fits.
you mentioned about the speed on earlier post
you have a hydrostatic tractor
you can press the foot pedal down and then pull the lever bewteen your feet with numbers 1-10 if you pull it all the way down it lock the speed that you are in so you can take your foot off the pedal and it will maintain that speed.
this is good for cutting large lawns.
if you depress the clutch and put in high range you should go around 15 mph
i have read alot of articles about our 1210 and hey say they are good little tractors.
keep up on the regular maintance and it should last long.
make sure you use a counter weight box in back (home made works fine) when using bucket alone.
the best part is you can play around with ideas and homemade projects and use them for your tractor.
keep in touch:)
