Filling tires with ballast at home.
   / Filling tires with ballast at home.
I would have at least considered all iron weights if it were possible to reach the required weight with them. But on my tractor it's not possible. I can fit 400 lbs or iron on each wheel, but need 1000 lbs. Different wheels can accept larger weights, and possibly reach the desired 1000 lbs, but not the wheels I happened to end up with. Also, iron is considerably more expensive at about $2/lb vs less than $0.50/lb for the various liquids.
   / Filling tires with ballast at home. #62
I dont know how to do the math, but I used 1 gal of -40 degrees anti freeze, with about 12 gallons of water. I likely didnt even need to add the anti freeze, but it was cheap.
Main thing I was worried about was breaking the beed on the tire, so I did jack it up somewhat, so that the rim wasnt on the ground, but also not too high, like where the tire was smashed about 1/3rd down; and no issue.
Edit: I tried to run that question through Deepseek, and its still arguing with its self, in circles, about different things; but eventually spit out 26 degrees F as the likely freeze point. Plenty of protection, considering no matter how cold it gets, the ground doesn't freeze, and the rubber also insulalates the mix, and although we get pretty dang cold, we never get 24 hours straight below 32
   / Filling tires with ballast at home. #63
This is going to be the case on almost any CUT running turf or R4 tires. Only R1's have wheel sizes large enough to carry weights approaching parity with beet juice or calcium chloride, at the scale of most CUT's.
   / Filling tires with ballast at home. #64
I agree, and that's what drove me to use RV antifreeze. I had a valve stem busted off my a branch when I had calcium chloride in my tires, and that was a big mess. I was pretty far into the woods and drove out as fast as I could while the stuff sprayed out in a big circle and the tire became flatter and flatter.
That must have been quite a sight.
Thankfully I got to forest road where I could then get it on a trailer.
Repair and/or replacing tires requires pumping all the stuff out, the filling back up again, so a bunch of extra work and expense as well.
Similar situation happened to me with beet juice never again for me. Mine broke near customers house and their dogs came out and started licking up the gross liquid, owner freaking out that her dogs were going to die, etc. (even though it was beet juice)
Never again.
   / Filling tires with ballast at home. #65
I have a JD2555 4x4 with loader that I bought used in SW TN. I didn't want to go after it, and finally worked out a deal with the seller for him to bring it halfway. The reason was the rear tires on it were seriously heavy. If they had been filled with liquid, I could have drained them, but they were foam filled so that was wasn't an option. The seller said they were 3500 pounds each. I don't know if that is correct or not, but I do know that I have been able to use the FEL for everything that I have needed to so far with no implement or counterweight on the rear. I also have not had any rear flat tires!
David from jax
   / Filling tires with ballast at home. #66
Filling tires with ballast must be as old as rubber tires. The fitting used to fill the Deere 1939A sits along with other tools of the trade.
   / Filling tires with ballast at home. #67
Thanks.
That gave me my first chuckle of the day...stay warm and have fun.
   / Filling tires with ballast at home. #68
Thanks.
Yup. I regularly experience folk with no knowledge on a subject that rely on AI responses. And then they ask for an opinion. Why? Just go, do, and learn. Just like AI does. The difference is you have opposing thumbs and a brain - something AI will never have because it scrapes someone else's experience that is supposed to fit your situation. Many/sometimes it doesn't. But then they go right back to AI asking why or what went wrong.
Ya can't make this stuff up.
   / Filling tires with ballast at home. #69
Oh, I know my weather, but no, i can't figure 1 gal at -40, mixed with 12 gal of tap water, and figure out the number of hours at what temp im rated for. Most people run straight water, but I figured for $5/tire why not add some freeze and corrosion resistance.
Yeah im sure there is a formula I could find, but, nope, dont care that much. We arent building space ships, we are filling tires
   / Filling tires with ballast at home. #70
Start with jacking up the tire free from the ground, tyre valve at the highest point and take the inner part of the valve out. Then take a very thin tube, thin enough to pass freely through the valve, and put one end tight-fitting through the cap of a 1.5 litre Coke bottle. Cut the bottom out of the bottle, hang it upside down over the tyre and stick the other hose end into the valve. Fill the bottle with the liquid and go and do something meaningful. Come back after a few hours, refill, again go do and repeat until the valve overflows. Close valve, blow air and let the jack down. In the US, take a one gallon milk container; saves you checking ever so often. Takes quite some time but very cheap and I have a national reputation to keep up, don't I?
Red Iron Oxide in Trace Mineral Supplements for Cattle
Red Iron Oxide in...
2019 TAKEUCHI TL12V2 SKID STEER (A52707)
2019 TAKEUCHI...
2016 Ford Taurus AWD Sedan (A55853)
2016 Ford Taurus...
2015 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A55852)
2015 Chevrolet...
UNUSED FUTURE 13" MINI GRAPPLE (A57193)
UNUSED FUTURE 13"...
2012 RAM 5500 Bucket Truck - Cummins Diesel - Automatic - 4X4 - Versalift SST40 Boom (A55302)
2012 RAM 5500...
