Filling tires with ballast at home.
   / Filling tires with ballast at home. #11
Living in the desert, freezing is not a big issue. It does get below 32, but it warms up during the day to above freezing. No issues for 20 years. I did add a couple of gallons of RV antifreeze to each tire as a little buffer for the colder days, and since water could cause rust in the wheel, I added 2 cans of auto water pump lube in each tire as it minimizes rust in the system and doesn’t hurt rubber.
   / Filling tires with ballast at home. #12
Thanks for the post - always interested to see how folks accomplish this task. Tractor owners have discussed/debated/argued/fought over what to use for rear wheel ballast for many years now. Rather than stoke those fires, I thought I would use the latest version of ChatGPT (AI), and I asked this question:
"How does using RimGuard compare to using RV antifreeze or windshield washer and water combinations?" It only took seconds before I got this response:
Great question — lots of tractor owners debate RimGuard (beet juice) versus RV antifreeze and windshield washer fluid/water mixes. Each has different long-range implications for weight, freeze protection, safety, cost, and maintenance. Here’s a side-by-side breakdown:
1. Weight (Ballast Value)
RimGuard (beet juice): ~10.7–11.0 lb/gal. Heavier than water, washer fluid, or RV antifreeze, so you get more weight in the same tire volume.
RV Antifreeze (propylene glycol): ~8.3–8.6 lb/gal (similar to water). Much lighter than RimGuard, so you’d need larger tires or more volume to get equivalent weight.
Windshield washer fluid + water: ~7.6–8.0 lb/gal depending on mix. Also lighter, similar to RV antifreeze.
👉 If maximum ballast is your priority, RimGuard wins hands-down.
2. Freeze Protection
RimGuard: Good to about -35°F (manufacturer spec). Works in most U.S./Canada climates.
RV Antifreeze: Usually protects to about -20°F to -50°F, depending on concentration. Very reliable for cold weather.
Washer fluid: Cheap blue washer fluid is generally good to -20°F, some premium types to -25°F. Mixed with water, protection drops proportionally.
👉 In very cold climates (northern tier), RV antifreeze is safest, though RimGuard usually holds up fine unless you’re in Arctic temps.
3. Corrosion & Rim Life
RimGuard: Non-corrosive. Doesn’t attack rims like calcium chloride.
RV Antifreeze: Non-corrosive. Safe for rims and rubber.
Washer fluid: Usually non-corrosive (mostly water + methanol + dye). Generally safe, though cheaper formulations may have additives that are harsher on rubber long-term.
👉 All three are better than calcium chloride. RimGuard and RV antifreeze are most rim-friendly.
4. Safety / Environmental Impact
RimGuard: Non-toxic, biodegradable, safe for livestock, pets, crops. A spill is a sticky mess, but not poisonous.
RV Antifreeze: Propylene glycol is considered “low toxicity,” but not something you’d want in soil or near livestock in quantity.
Washer fluid: Contains methanol, which is toxic to pets, livestock, and people. A leak or spill in a pasture or near animals could be risky.
👉 For farms with animals or kids around, RimGuard is by far the safest.
5. Cost & Availability
RimGuard: Usually $3–4 per gallon installed at a dealer. You pay for the product + service. Not DIY-friendly unless you have the pump setup.
RV Antifreeze: $2–3/gal retail (cheaper in bulk, especially off-season). DIY-friendly.
Washer fluid: Cheapest option, sometimes <$2/gal at big box stores. Easy DIY fill.
👉 Washer fluid is cheapest, but RimGuard costs more because of its weight advantage and environmental safety.
6. Practical Maintenance / Long-Range Issues
RimGuard:
Heavy → more stress on axles/bearings (true for any ballast).
Can be messy if you ever have to drain it.
Valve stems need to be liquid-rated to avoid clogging/leaks.
RV Antifreeze:
Light → may not provide enough counterweight for loader work.
Easy to top off or replace if a tube fails.
Washer fluid:
Lightest ballast, so often insufficient for heavy work.
Toxicity risk if a tube leaks into a barnyard or field.
Methanol can evaporate slowly through rubber tubes over years, reducing freeze protection.
Bottom Line
If you want maximum weight, long-term rim protection, and farm-safe environmental qualities → RimGuard is best (but higher cost, dealer install).
If you want a cheap, DIY, decent freeze-proof fill and don’t need maximum weight → RV antifreeze is a safer choice than washer fluid.
If you just want something quick and inexpensive, and you don’t have animals around → windshield washer fluid works, but it’s light and carries a toxicity risk.
👉 A good rule of thumb:
Heavy loader work / hilly terrain / livestock nearby → RimGuard.
Moderate work / DIY budget-conscious → RV antifreeze.
Light duty / cheapest option → washer fluid.
   / Filling tires with ballast at home. #13
what's wrong with water?? now I'm in Australia before you shout dumb question
Nothing at all. Best choice, as long as freeze protection isn't required.
RimGuard:
RV Antifreeze:
Washer fluid:
Bottom Line
Interestingly, this doesn't flag the issue with RV Antifreeze, which is that it becomes solid, or semi-solid at around 5F despite the "protection to -50F" headline. "Protection to -50F" is because it doesn't expand, even though it does become solid, and hence unsuitable as ballast. Also, the text presumes that RV Antifreeze is prop glycol based, and from what I have seen, few are. Most seem to be a combination of ethanol, glycerol, and propanol.
It also says that RimGuard is not DIY friendly because it requires a pump. Well, all of them require a pump. RimGuard isn't DIY friendly because you can't buy it for self-install.
So AI is just like any other source of info - partially correct, partially incorrect, and you need to figure out which parts or correct and which are not.
I remember a popular line from the early days of computing: "To err is human. To really foul things up requires a computer" It's never been more true.
   / Filling tires with ballast at home. #17
Does ballast affect the handling of the tractor?
Yes. Better stability, obviously, but also a rougher ride with much less compressible air volume remaining in tire. All of these liquids are non-compressible, from the practical standpoint of tire pressures.
  • Good Post
Reactions: bgr
   / Filling tires with ballast at home. #18
How much did the antifreeze cost you?
I bought the little valve years ago and just never got around to filling them. It is something I still want to do. I am in southeast Tennessee and we rarely get temps below freezing for days on end, but it does happen. I think I could get away with a mix of water and some type of antifreeze. Interested to hear some of the responses as it has been a while since I have looked into this.
   / Filling tires with ballast at home. #19
Thanks everyone. I need to do this with my JD 2038R. I wonder how many gallons needed? An AI bot says about 35 gallons per tire. It has ag tires -- need real tires in the dirt and moving around in the foothills.
   / Filling tires with ballast at home. #20
AI is just an automated web search robot that doesn't know if its right or wrong.
Question... how do you know when you are at the level you want?
MARATHON 20KW GENERATOR (A58214)
MARATHON 20KW...
2011 GMC Sierra 1500 (A56858)
2011 GMC Sierra...
2014 Takeuchi TB290 Mini Excavator, S/N 1851007797, Diesel Engine, Tag 24" Bucket w/Thumb, 18" Wide (A59076)
2014 Takeuchi...
2014 Ford Fusion SE Sedan (A55758)
2014 Ford Fusion...
2017 John Deere 6120E (A53317)
2017 John Deere...
2017 Komatsu PC490-11 Hydraulic Excavator, S/N A41596, PIN# KMTPC251JHWA41596, Turbo Diesel Engine, (A59076)
2017 Komatsu...
