Filling a cistern
/ Filling a cistern #1
Number15
Rhea County TN
AC 7600 TTR, Branson 5520CH, Grasshopper 928D2
Found what I think is a cistern while mowing the other day. Luckily I saw it as I think it could have been disastrous if a tractor wheel found it first.
it's around 5ish feet in diameter and lined with some kind of mortar or clay and concrete. PO seems to have tried to fill it with tree parts but I am thinking that is not the best solution.
Right now it looks like an awesome burn pit. I will however need to fill this, it is to big of a liability. Should I remove/burn the wood that is in there? I am thinking as it rots it will settle. When filling should I use all dirt? I was thinking perhaps fill it with some kind of rock and topping it with dirt. Or should I go full bore and call the concrete truck :) I have no idea how deep it is at this point.
/ Filling a cistern #3
Got a gravel pit close..?? Concrete, or fill sand would probably be better to work it's way down around those chunks of wood. Make a slight mound as mentioned, and every time it rains, it will wash the sand down around those pieces of wood. You could pull out what you can to get a good start. Burning may be an option for the very top, but doubt it wil burn very deep, because of lack of oxygen, unless you provide an air source. I'd imagine the wood that's down a few feet is water logged anyway.
/ Filling a cistern #4
I’d pull the wood out or burn in place if it will burn and then fill with dirt.
/ Filling a cistern #5
Pull all that wood out down to at least 6’. Look for ladder type inset steps in the sides. Climb down with cordless grinder, when you find the door near the bottom, cut the lock and possibly the hinges if exposed on the outside. Once inside, carefully film and document all WW2 weapons and post on TBN so we can help identify. DO NOT touch hand grenades if found! 😬 Look for tunnels leading back to house. Inspect with caution.(y)
I would not go down in it. Too much chance of some type of gas that could overwhelm you. Very dangerous. Do all your work from top where you are in fresh air
/ Filling a cistern
Don't worry, I have no intention of going into it
/ Filling a cistern #7
Ya, you’d probably fall into a farmers home made septic tank:ROFLMAO::ROFLMAO:
/ Filling a cistern #9
My dad was always rebuilding the tv, but we went to thrifty where they had the tester and spare tubes. Crappy TVs, but could be repaired for a few bucks
/ Filling a cistern #10
pull Most of the wood out. I doubt it will burn in place, it would be hard for combustion air to get in.
knock a couple of feet off the top so it is below ground level. Then back fill with reject concrete sand. It tends to be self consolidating. The other option, but more expensive, would be a Controlled Low Strength Material. Essentially a 3/8-inch minus Portland Cement, with only 1/2 to 3/4 sacks per yard, a high water to cement ratio, and plasticizer added. It should have a 10 or 11-inch slump so it is self leveling.
/ Filling a cistern #11
Do you know for sure this is a cistern of any depth and not just a camp fire ring? How big is this property? Do you know the history? Could it have been used to heat branding irons? If it was long enough ago, any signs of previous fires may have worn off.
/ Filling a cistern
It's for sure a cistern. or an open septic tank LoL
/ Filling a cistern
What if I made a pipe with a 90 degree on it and shoved one end down as far as I could and put a fan on the other end? You think that would keep the fire going for awhile and burn this stuff? I really don't want to remove the tree stuff by hand, it looks like a lot.
/ Filling a cistern #14
When burning brush. I have used my Stihl BG86 leaf blower It works fantastic to add air and move the fire to other parts of the pile. Take a piece of pipe / tubing tape it up and she will burn
/ Filling a cistern #15
It might burn with forced air if it’s dry enough. The chances of it burning unassisted is about zero.
/ Filling a cistern #16
If your curious enough drive metal pipe etc. down to see how deep before bottom.
Fill it with flat rocks than dirt.
/ Filling a cistern #17
open or abandoned wells, holes etc can be a source of ground water contamination depending on the aquifer...if there are any wells nearby being used for potable water special care should be taken with back filling...
/ Filling a cistern #18
Looks like you got about 10" of rain in your area last month.
Clear around it so if and when you start a fire there is no problem.
I'd wait for it to dry out a fair bit, then when it's safe (and legal, maybe contact the fire dept.) hook your blower up to a pipe, spray in an appropriate amount of diesel and let the flames consume what they will.
/ Filling a cistern #19
What is near the object. If nothing important, overfill with dirt and let it settle and rot. Add dirt as needed. Burning will only speed the process up
New/Unused ATS T460 Mini Skidsteer (A65583)
New/Unused ATS...
2018 PETERBILT 567 (A65643)
2018 PETERBILT 567...
2018 Bobcat T590 (A64126)
2018 Bobcat T590...
2021 Sol Grand Design BK390 Camper (A62613)
2021 Sol Grand...
Skid Steer Pile Hammer (A65640)
Skid Steer Pile...
2015 Polaris Sportsman 570 AWD ATV (A64557)
2015 Polaris...
