Filled tire problem
   / Filled tire problem
It is a Kioti with tubeless tires.
   / Filled tire problem #13
Only asked what make because I have never heard of this happening before. I do agree with others and suspect that it is related to the tire pressure that you are running. Have you checked the pressure of the tire(s) that are spinning on the rim?
   / Filled tire problem #14
   / Filled tire problem #15
Several years ago I had a flat on a tubed- CC filled tire- same symptoms you have. Since you are tuble-less I would try jacking it up and trying to seat the bead- if that doesn't work, you are going to have to drain it and start over. Even if you can get it to seat, why did it go flat in the first place???
   / Filled tire problem #16
The tire never went flat and never lost any fluid. It is properly inflated, and I even added extra air to the tire hoping to tighten the bead to the rim. The bead didn't separate from the rim, but the Rim Guard is acting like a lubricant between the rim and the bead. I will be contacting the company today to see what they suggest.
   / Filled tire problem #19
Please post what you find, as this is a new one on me!
jb
   / Filled tire problem #20
jb
2021 SANY SY365C9C5K (A58214)
2021 SANY...
2018 Honda Rubicon TRX500FA5 4X4 ATV (A59231)
2018 Honda Rubicon...
2024 CATERPILLAR 259D3 SKID STEER (A60429)
2024 CATERPILLAR...
John Deere 855DXUV Gator (A57148)
John Deere 855DXUV...
2000 Case 590 SL Backhoe Loader (A59814)
2000 Case 590 SL...
2024 Frontier FL1061S Hydraulic Flail Mower (A56438)
2024 Frontier...
