Filled tire problem
   / Filled tire problem
It is a Kioti with tubeless tires.
   / Filled tire problem #13
Only asked what make because I have never heard of this happening before. I do agree with others and suspect that it is related to the tire pressure that you are running. Have you checked the pressure of the tire(s) that are spinning on the rim?
   / Filled tire problem #14
   / Filled tire problem #15
Several years ago I had a flat on a tubed- CC filled tire- same symptoms you have. Since you are tuble-less I would try jacking it up and trying to seat the bead- if that doesn't work, you are going to have to drain it and start over. Even if you can get it to seat, why did it go flat in the first place???
   / Filled tire problem #16
The tire never went flat and never lost any fluid. It is properly inflated, and I even added extra air to the tire hoping to tighten the bead to the rim. The bead didn't separate from the rim, but the Rim Guard is acting like a lubricant between the rim and the bead. I will be contacting the company today to see what they suggest.
   / Filled tire problem #19
Please post what you find, as this is a new one on me!
jb
   / Filled tire problem #20
jb
2011 NORAM POWER SYSTEMS 100KW GENERATOR (A58214)
2011 NORAM POWER...
2011 SHOP MANIFOLD TRAILER (A58214)
2011 SHOP MANIFOLD...
2017 VOLVO VNL64T TANDEM AXLE SLEEPER TRUCK (A59575)
2017 VOLVO VNL64T...
2022 Schulte SMR-800 Multi Rake Landscape Windrower (A56438)
2022 Schulte...
WBrock Meyer 2000S 70'x12' 2000 BPH Grain Dryer W/Legs&Mill Discharge Sylo,Controller is included (A57148)
WBrock Meyer 2000S...
Club Car Carryall 2 Electric Utility Cart (A55851)
Club Car Carryall...
